ABS light fuse
Old Oct 15, 2007 | 03:31 PM
tigerbait's Avatar
Default ABS light fuse
I've got a '96 Accord. The ABS light stays on.
I don't want to fix the ABS. I just want to turn the ABS light off.
What's the best way to do this? Take the time to open the dash and everything and pluck the light out? Is there a fuse somewhere I can pull? I still want the other lights (SRS, Check Engine, etc.) to come on in the future if something does go wrong with them so if the fuse controls that entire cluster of lights, I'd rather not do that.
Thanks in advance!
Old Oct 15, 2007 | 03:39 PM
kornfox's Avatar
Default Re: ABS light fuse (tigerbait)
If Im not mistaken, even if you take out the fuse, all that would do is turn the light on. In your case, its already on so i'd say its bulb pulling time.
Old Oct 15, 2007 | 04:46 PM
tigerbait's Avatar
Default Re: ABS light fuse (kornfox)
Thanks, kornfox!
I did not know that about the fuse. I'm glad you saved me the trouble of figuring that out on my own.
Guess it's time to pull out the ole shop manual this weekend. I've never taken apart the dash on a Honda before.
Old Oct 15, 2007 | 05:02 PM
TheMuffinMan's Avatar
He knows where you live!
Accord FAQ
cluster removal, there's one with pics based off of my text
Old Oct 15, 2007 | 05:43 PM
tigerbait's Avatar
Default Re: (TheMuffinMan)
TheMuffinMan,
That is going to be a tremendous help for me. Thank you!
Old Oct 15, 2007 | 05:49 PM
Yep, got tired of explaining it haha
Wrote that up and the other guy took all the pics
Old Oct 22, 2007 | 01:46 PM
tigerbait's Avatar
UPDATE: Problem solved. Followed the instructions from above and took the ABS light off. Took about 4.5 hours solo.
Instructions worked like a charm until I had to disconnect the 3 harnesses from the cluster. I was feeling around BEHIND the cluster instead of ABOVE the cluster. Finally found them, but my hands are too big to really maneuver well.
The ABS light is very clearly labeled, which took all of the guesswork out. I also fixed my radio while I had everything apart. Now I can catch AM stations.
Best of all: no broken parts and no rattles.
Thanks for all the help!
bakomack
Aug 30, 2010 08:00 AM
JaysonDC2
Dec 9, 2009 10:58 AM
craiger28
Nov 12, 2009 05:38 PM
coregis
Jun 16, 2009 10:20 PM
mitcho
May 1, 2009 04:06 PM
