Confusing valvetrain noise....
Old Oct 15, 2007 | 01:07 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Confusing valvetrain noise....
OK, here we go, this is all on a obd0 b16 mind you.
I had a weird lil raspy tick from the top end of my motor, so i went ahead and adjusted all my valve lashes and they were all well within specs.... but the rasp is still there, it got a bit quieter but is still present. at this point i'd have to figure its the cam follower thats making noise, which brings me to my question... is it the follower that usually wears out or where it mounts? I'd like to refresh this head and use it on another motor when i put my LS swap in, but I want to know if this is an issue that anyone else has come across. any help is more then appreciated. Thanks
Old Oct 15, 2007 | 01:16 PM
crxfreak1117's Avatar
Default Re: Confusing valvetrain noise.... (ComeOnKip)
almost possitive its ur LMA'S
Old Oct 15, 2007 | 02:45 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Confusing valvetrain noise.... (crxfreak1117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">almost positive its your LMA'S</TD></TR></TABLE>
That would also be my guess..
Search "Lost Motion Assemblies" under the archived content..
Old Oct 15, 2007 | 02:53 PM
ComeOnKip's Avatar
I will do some research on that. If it is, easily replacable with the rest of the valvetrain out?
Old Oct 15, 2007 | 03:04 PM
88DXCRX's Avatar
Default Re: (ComeOnKip)
You can replace them by removing the rockers and rocker shafts..
The cams do not have to be removed...
Some info here:
https://honda-tech.com/zerothread?id=726701
PS&gt;In my case that was definitely the problem as
it was in several other instances I had read about...
Old Oct 15, 2007 | 03:37 PM
ComeOnKip's Avatar
and who says theres no tech left on HT?
Thanks guys.
Old Oct 15, 2007 | 07:18 PM
ComeOnKip's Avatar
So the jist i'm getting from these threads is to upgrade to the gs-r LMAs because the 1st gen b16s are funked?
Old Oct 16, 2007 | 05:14 PM
well anything thats almost 20 years old usually goes bad eventually... so just put some gsr's but there like 30 bucks apiece but u can use h22 lma's and there like 8 bucks apiece but u will have to shim them
Old Oct 17, 2007 | 04:48 AM
ComeOnKip's Avatar
i'd rather use the right part and not have to boo-rig it. Thanks for the input!
Old Oct 17, 2007 | 08:43 AM
GOOD CHOICE
teg racer 877
Oct 13, 2008 03:34 AM
obuhmyuh
48
Feb 8, 2008 11:42 PM
ph0shizzle
Aug 9, 2006 04:38 PM
KRiS1
Sep 2, 2003 04:09 PM
EL Vap133
Apr 15, 2003 05:50 PM
