transmission question s80
Old Oct 15, 2007 | 12:03 PM
b17eg's Avatar
Default transmission question s80
on my tranny it has the s80 sticker on it. but my question is how can i tell if its an ls or gsr tranny? im pretty sure its a gsr but how can i tell for sure?? any help would be appreciated.
Old Oct 15, 2007 | 12:11 PM
klungemonger's Avatar
One way is to open the case and count the ring gear teeth...hehe. 66 teeth is GSR, 64 teeth is LS.
Otherwise you will have to get the list of gear ratios, figure out the % drop between gears. Drive at some certain rpm, shift and see what rpm you end up at. Since 1-2 gears are the same between LS & GSR you need to do it shifting from 2-3, 3-4, or 4-5. There are more complicated math equations you can do but they also involve driving around, writing down rpm, speed, knowing tire size, blah blah. If this other method don't work just ask I'll post that up if someone else hasn't already...
Old Oct 15, 2007 | 01:05 PM
i.'s Avatar
i.
an easier was is see what your rpms are in 5th gear, at about 60 mph, level road.
the gsr fifth will be way higher than the ls. at 60 in 5th, the ls will be spinning somewhere AROUND 2600, give or take. the gsr will be closer to 3000, (an the b16 trans will be a little higher than that)
Old Oct 15, 2007 | 02:18 PM
b17eg's Avatar
Default Re: (i.)
ill try those ideas out. thanks for the posts. ill post it up when i figure it out maybe later on today.
Old Oct 15, 2007 | 02:21 PM
siregcivic's Avatar
Default Re: (i.)
type r trannys are also s80... but you would know if you have a type r you would be at 4k+ at 70
Old Oct 15, 2007 | 02:52 PM
Bense's Avatar
4000rpm @ 80mph with 205/50/15s = gsr
4450rpm @ 80mph with 205/50/15s = b16/itr
Old Oct 15, 2007 | 07:11 PM
b17eg's Avatar
Default Re: (Bense)
in 5th gear going 60mph it was at 3k. this was on 195/60/r14 tires.
Old Oct 15, 2007 | 07:27 PM
Sounds like GSR...
cheesebeast
Transmission & Drivetrain
Dec 8, 2011 07:33 AM
b20vtecEK
Jan 25, 2005 05:27 AM
jdm_gsr
Feb 11, 2004 05:55 AM
Jonathan_ED3
Apr 19, 2002 12:06 AM
Muglit
Feb 19, 2002 07:54 PM
