Thumping noise coming from axle
Old Oct 14, 2007 | 09:36 PM
dc2doi's Avatar
Default Thumping noise coming from axle
I got this thumping noise coming from the driver side axle.
The axle was just replaced 200 miles ago.
No CV boot are torn.
Lower control arm ball joint has about 2mm of play.
I had the car on jack stands, turn the wheel all the way to the left.
Step on the gas and heard the thumping noise, when its straight
there is no noise or to the right. There were no tires on.
Driving the car I would hear the thumping always.
Could it be a bad axle? mid shaft? could the ball joint be causing this?
Old Oct 14, 2007 | 09:39 PM
Duane_in_Japan's Avatar
Default Re: Thumping noise coming from axle (dc2doi)
CV joint or hub bearing, would not be the first time a bad rebuilt joint was sold.
Old Oct 15, 2007 | 12:28 AM
dc2doi's Avatar
bed time bump.
Old Oct 15, 2007 | 06:23 AM
italianchooch88's Avatar
id guess wheel bearing..
Old Oct 15, 2007 | 07:03 AM
weavertime1's Avatar
Sounds like a wheel bearing. You could always check it with a mechanics stethoscope on jack stands with the wheel off. It will def. make an obnoxious noise through the stethoscope if it is the bearing. Also, drive the car and turn the wheel left and right while driving down the road. Make sure no one is coming obviously. If it is the wheel bearing it will go away when you turn away and return when you straighten out. Good Luck!!!
Old Oct 15, 2007 | 07:05 AM
Also, as Duane_in_Japan stated, It is very possible to have a new CV bad. My dad owns a garage, and we see it 1 out of every 25 or so.
Old Oct 15, 2007 | 11:02 AM
dc2doi's Avatar
When I turn left its quieter. So lets say I turn left which side could this be?
Old Oct 15, 2007 | 11:08 AM
dizzzane's Avatar
Default Re: (dc2doi)
Generally its the opposite way you turn the wheel (it stretches the axle when your turn it opposite)
Old Oct 15, 2007 | 11:23 AM
Default Re: (dizzzane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">Generally its the opposite way you turn the wheel (it stretches the axle when your turn it opposite) </TD></TR></TABLE>
Agreed...usually its the opposite one of the way you turn. To be sure I always use the stethoscope.
tobytigger
Jan 11, 2014 01:41 PM
Knightrider03m
May 29, 2013 05:06 AM
SHystrdyGSRtdy
Mar 4, 2013 01:24 PM
Steve LeB
Oct 28, 2011 11:58 PM
fstgsr
Oct 29, 2003 09:03 AM
