oem 81.5mm head gasket
Old Oct 14, 2007 | 09:21 PM
panda_eh2's Avatar
Default oem 81.5mm head gasket
where can i get a good headgsaket for my 95 gsr thats bored to 81.5mm? i've had nothing but problems with my .051 cometic. oh and i need this gasket asap
Old Oct 14, 2007 | 09:43 PM
mighty137's Avatar
Just use the OEM stock one....not that huge of a diff to get a cometic 81.5mm...
Old Oct 14, 2007 | 11:35 PM
riceball777's Avatar
Default Re: (mighty137)
stock is fine for 81.5mm
Old Oct 15, 2007 | 06:45 AM
panda_eh2's Avatar
thanks alot. all i've had was problems with the cometic one i bought. air has been getting into my cooling system and causing coolant lines to expload for about a week. what should i tourque my arp head studs down to with a stock gasket?
Old Nov 24, 2007 | 08:30 PM
Shoei7's Avatar
Default Re: (panda_eh2)
hi dude, where did you find this HG ??, i~m looking for this gasket, with 81,5mm to B16, OEM .... the HOnda dealer next me, told me that Oem HG comes with 81,25 maximum mm...
i have problems with cometic, and i'll change this...
could help me?
Old Nov 25, 2007 | 10:24 AM
blackeg's Avatar
Default Re: (Shoei7)
just use the regular 81mm gasket, it will work fine
Old Nov 25, 2007 | 12:41 PM
BadWay's Avatar
Default Re: (blackeg)
golden eagle has the factory honda gaskets bored to match your engine bore
Old Nov 25, 2007 | 04:12 PM
lambertincorp's Avatar
Default Re: (BadWay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadWay &raquo;</TD></TR><TR><TD CLASS="quote">golden eagle has the factory honda gaskets bored to match your engine bore</TD></TR></TABLE>
Old Nov 25, 2007 | 04:35 PM
Garage 808 Hatch's Avatar
a stock gasket works fine on a 81.5mm bore. /thread
Old Nov 25, 2007 | 07:48 PM
turbolshatch's Avatar
Default Re: (Garage 808 Hatch)
A stock honda 81 mm gasket will work with no problems but if you really want an 81.5 golden eagle sells them
Old Dec 11, 2007 | 08:54 AM
blackcherry's Avatar
if im going turbo with my gsr, will a stock head gasket from autozone be any different than one from golden eagle? are the golden eagle/ oem ones better for turbo?
Old Dec 11, 2007 | 08:56 AM
morgan@synapse motorsport's Avatar
Default Re: (blackcherry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcherry &raquo;</TD></TR><TR><TD CLASS="quote">if im going turbo with my gsr, will a stock head gasket from autozone be any different than one from golden eagle? are the golden eagle/ oem ones better for turbo?</TD></TR></TABLE>
get a genuine head gasket from a dealership, or online dealership. im not sure what brands autozone carries but i wouldnt bank on it. the golden eagle ones are OEM honda head gaskets overbored. unless you are going over 82mm a stock one will work fine with no machining.
Old Dec 11, 2007 | 09:06 AM
that sounds cool, but i think a stock golden eagle one is like 30 or 40 cheaper than my local dealership.... and do you think the head gasket is the only important one to change, or the whole upper engine kit should be done?
Old Dec 11, 2007 | 09:07 AM
oh and btw, the dealership said the kit for the head is like 250.....
Old Dec 11, 2007 | 09:11 AM
retail on a head gasket is $80.57 from a dealer i believe i dont think GE sells them for 40 bucks.
Old Dec 11, 2007 | 11:02 AM
CerealKiller's Avatar
Default Re: (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">retail on a head gasket is $80.57 from a dealer i believe i dont think GE sells them for 40 bucks.
Yeah, GE's price is like $93.00. Stock gasket is fine.
Old Dec 11, 2007 | 11:56 AM
yakuza's Avatar
Just on this topic, anyone seen the gasket kits on http://www.cnsautoparts.com? The prices are way too good but has anyone tried them before?
Old Dec 11, 2007 | 01:58 PM
Default Re: (yakuza)
nope, but wouldn't trust anything but stock.
Old Dec 11, 2007 | 06:59 PM
yakuza's Avatar
Default Re: (CerealKiller)
You might be right there. I have done some search on Eristic gaskets of ebay and the general feedback wasn't that well at all. I'll most likely go with Victor Reinz gaskets from http://www.cnc-motorsports.com. Bit over my budget but a $150 extra now, better than a leaky gasket and then more time and new parts again ...
Old Dec 12, 2007 | 10:34 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakuza &raquo;</TD></TR><TR><TD CLASS="quote">You might be right there. I have done some search on Eristic gaskets of ebay and the general feedback wasn't that well at all. I'll most likely go with Victor Reinz gaskets from http://www.cnc-motorsports.com. Bit over my budget but a $150 extra now, better than a leaky gasket and then more time and new parts again ...</TD></TR></TABLE>
Wow...people really don't listen on this forum!
There are multiple guys on here making 700-800+whp, and run OEM headgaskets!
Old Dec 12, 2007 | 01:03 PM
yakuza's Avatar
Default Re: (boostincoupe)
They do listen, but they don't have to take the 1st advise that comes their way do they?
Seen posts all about OEM and it will do just fine, seen posts about comestic and even is after market and cost more people did have problems with them.
I'm now going Vector Reinz, well known and its standard MLS OEM fitment.
Old Dec 12, 2007 | 01:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakuza &raquo;</TD></TR><TR><TD CLASS="quote">They do listen, but they don't have to take the 1st advise that comes their way do they?
I'm now going Vector Reinz, well known and its standard MLS OEM fitment.</TD></TR></TABLE>
So you're spending MORE than the cost of a proven OEM headgasket, because YOU'RE convinced it's better (as opposed to the pro-racers and sick 600-800whp street cars on this site that swear by OEM gaskets)?
Old Dec 12, 2007 | 01:16 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
golden eagle.. its OEM honda bored to your size... can't go wrong
Old Dec 12, 2007 | 01:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CerealKiller &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^^^
nope, but wouldn't trust anything but stock.</TD></TR></TABLE>
get a genuine head gasket from a dealership, or online dealership. im not sure what brands autozone carries but i wouldnt bank on it. the golden eagle ones are OEM honda head gaskets overbored. unless you are going over 82mm a stock one will work fine with no machining.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbolshatch &raquo;</TD></TR><TR><TD CLASS="quote">A stock honda 81 mm gasket will work with no problems but if you really want an 81.5 golden eagle sells them </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">a stock gasket works fine on a 81.5mm bore. /thread</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">just use the regular 81mm gasket, it will work fine</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">stock is fine for 81.5mm</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mighty137 &raquo;</TD></TR><TR><TD CLASS="quote">Just use the OEM stock one....not that huge of a diff to get a cometic 81.5mm...
1st advice they get, right?
Old Dec 12, 2007 | 01:27 PM
yakuza's Avatar
Someone lock this thread please, else boostincoupe will keep slagin us for asking too much questions ..
