transmission grinds
Old Oct 14, 2007 | 09:14 PM
SandaBo's Avatar
Default transmission grinds
Hi ppl im new to HT and was trying to see how to use this.I have a stock 95 rs.Had it for some time now and the transmission started to grind when i go to put it in to 3rd and 5th.Gos in to 5th but when i let off the gas it comes out but if i stay on the gas it gos good can anyone help?
Old Oct 14, 2007 | 09:22 PM
clean3two3's Avatar
Default Re: transmission grinds (SandaBo)
it could be the synchros.you can try this drain out your transmission fluid and put in syncromesh if that doesnt work then i guess you have to get your synchros repaired
Old Oct 14, 2007 | 09:28 PM
SandaBo's Avatar
Default Re: transmission grinds (clean3two3)
thanks
about how much would it cost to have that replaced would it be cheeper to jest get a usd tranny?
Old Oct 14, 2007 | 09:38 PM
clean3two3's Avatar
i dont know but 1st try letting out the fluid and ading new fluid if that doesnt work look around for a shop.i got the same problem but with 3rd gear sometimes it doesnt stick so i shift into higher rpms then it goes in or i jump third
Old Oct 14, 2007 | 09:40 PM
SandaBo's Avatar
Default Re: (clean3two3)
thanks for your help
B16Jacques
Sep 15, 2006 04:06 PM
bluels-t
Dec 13, 2004 12:37 PM
BrownGSR
Oct 13, 2003 02:01 PM
hmongdude
Jul 14, 2003 01:17 PM
fuck honda-tech
Apr 9, 2003 05:22 PM
