ls rods and crank in a gsr...
Old Oct 14, 2007 | 08:32 PM
jarvis199's Avatar
Default ls rods and crank in a gsr...
ok guys before i get flamed ill give u some history on this deal...
im building a gsr blcok with b16 head for a friend of mine, and we cannot located a good gsr crank, so i have a few ls cranks taht are beautiful lying around, and im just going to install it... the goal on this build is mid 400whp numbers on meth...
now the question is, i purchased 9:1 cp pistons (.020 over) for a gsr...
what compression ratio are those going to yield with an ls crank, ls rods, with those cp's on an unmilled b16 head?
Old Oct 15, 2007 | 06:50 AM
jarvis199's Avatar
Default Re: ls rods and crank in a gsr... (jarvis199)
bump?
Old Oct 15, 2007 | 08:22 AM
champLSinteg's Avatar
its going to be around .1 or .2 lower. so 8.9-8.8:1
Old Oct 15, 2007 | 10:40 AM
jarvis199's Avatar
Default Re: ls rods and crank in a gsr... (champLSinteg)
i understand that the b16 head will drop compression, but what about the ls crank and rods? wont that bump it back up?
Old Oct 15, 2007 | 12:12 PM
check it out!
http://www.c-speedracing.com/h...c.php
Old Oct 15, 2007 | 12:16 PM
jarvis199's Avatar
thanks but ive been there, the problem is im not sure if the deck height is different between the gsr and ls blocks???
gsr block+ls crank and rods +9.1 cp pistons (in a stock gsr)+b16 head=what comp ratio???
Old Oct 15, 2007 | 03:48 PM
TheShodan's Avatar
Moderator
Depends upon what you put it in. There are plenty of LS Rod/Crank and B16/GSR head combinations. The rods and crank aren't going to change your effective compression much, that's of course more in the head and piston that you use.
I've had plenty of those LS Crank/Rod combinations in a GS-R block with a B16 or GS-R head. The increase in torque is fantastic. When sleeved to 84mm with the 89mm stroke, its even moreso.
You'll be fine with that combination.
Old Oct 15, 2007 | 04:59 PM
the deck height on all b-series exept b16 is the same even b16b!
Old Oct 15, 2007 | 07:06 PM
jarvis199's Avatar
thanks guys!
flatblackfury91
Oct 27, 2012 08:38 AM
carlossolorzano
May 27, 2012 01:12 AM
VtecRexy
Oct 8, 2006 02:31 PM
bigmikerich20
Sep 20, 2005 07:01 AM
EF9SIRJeff
Aug 24, 2005 11:07 AM
