I am losing brake pressure....
Old Oct 14, 2007 | 06:45 PM
draperj09's Avatar
Default I am losing brake pressure....
i have been experiencing loss of brake pressure lately, you know, i got to pump my brakes at stop signs, that type of thing. so, i went ahead and replaced my back brake pads (front is good) and bled front and back. it is NOT leaking fluid but is losing pressure
Old Oct 14, 2007 | 07:02 PM
draperj09's Avatar
Default Re: I am losing brake pressure.... (draperj09)
could it be the master cylinder?
Old Oct 14, 2007 | 07:22 PM
efb16hatch's Avatar
edited didnt read that your not looseing fluid durrrr yea i would try the master cyl first
Old Oct 14, 2007 | 07:37 PM
draperj09's Avatar
Default Re: I am losing brake pressure.... (efb16hatch)
but don't they usually lose fluid when they go out?
Old Oct 14, 2007 | 07:50 PM
mini-me-power's Avatar
no, your cup seals are going out and there not holding pressure!
Old Oct 14, 2007 | 07:53 PM
SIred91's Avatar
Rainman
Default Re: (mini-me-power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-me-power &raquo;</TD></TR><TR><TD CLASS="quote">no, your cup seals are going out and there not holding pressure!</TD></TR></TABLE>
Replace the master cyl....and look for vaccuum leaks on the booster. That is common as well.
Old Oct 14, 2007 | 07:54 PM
92hatchboi's Avatar
yup change that master cylinder bro cuz once the brakes goes down we know its not ur brake booster
Old Oct 14, 2007 | 09:36 PM
oinojo's Avatar
do you have drum brakes? Make sure you adjust the drum shoes properly. I had the same issue but it ended up just being maladjusted brake drums.
Old Oct 15, 2007 | 12:52 PM
draperj09's Avatar
Default Re: I am losing brake pressure.... (oinojo)
thanks ill try that... and yes i have rear drums ill be double checking that too
Old Oct 15, 2007 | 04:57 PM
boosstboy's Avatar
yes, im not the only one! ya it sucks sitting at a light and have to keep repumping brakes so the car won't roll. it's the master mine's shot too i just been broke lately so i haven't replaced it yet. did it on my friends eg it fixed the problem.
Old Oct 16, 2007 | 12:23 PM
draperj09's Avatar
Default Re: I am losing brake pressure.... (boosstboy)
i just replaced the master cylinder, the power booster had a little brake fluid around it but the seal was good. there was more pedel travel but i wasn't losing pressure anymore. i bled my brakes, took it on a test drive, and there's a lot more pedel travel now. still holding pressure though.
Old Oct 16, 2007 | 12:55 PM
draperj09's Avatar
any ideas?
Old Oct 16, 2007 | 03:10 PM
boosstboy's Avatar
if the brake pedal engages low try adjusting the rod lenth on the brake pedal. is it a stock master for that year and model you put it on? if it is try rebleeding the master there might of been some trapped air in it. did you bench bleed the master with fluid before you installed on the car?
Old Oct 16, 2007 | 03:38 PM
hondacrx2's Avatar
i have 3 crx's and the all do the same thing. i put new brakes and lines and master cylinder and bleed them out. i just gave up. mine only happens once in a blue moon thou.
Old Oct 16, 2007 | 04:09 PM
cr-x-91's Avatar
u forgot to bench bleed the master cylinder...no big deal. just bleed brakes again. i would try like 5 times at each corner. and if u had a vacuum leak at the booster it would not cause pedal travel....you would have manual brakes and would not be able to press down on the brake pedal and make it move more than a half inch if that. the booster asist in aplying pressure. so just bleed them real good...good luck man
Old Oct 16, 2007 | 04:13 PM
RanCRX's Avatar
you might wanna look up the bleeding sequence as well. Could be a Z bleed, or X, I forget.
Old Oct 16, 2007 | 04:26 PM
cr-x-91's Avatar
its....rr,lr,rf,lf. basically the furthest from the master than next and so on.
Old Oct 18, 2007 | 03:03 PM
draperj09's Avatar
Default Re: (cr-x-91)
i already have done all that. in sequence. and the master cylinder. like i said they are great again. perfect pressure. but theres just more play in the pedel before the breaks grab. no biggy.
EFn-DirtySouth
Aug 7, 2011 06:41 PM
Turbo-Honda
Suspension & Brakes
Jan 11, 2007 08:22 PM
Gimpo
Dec 19, 2005 09:16 PM
TedR719
May 21, 2003 07:54 AM
eg_92vxhb
Nov 14, 2002 10:05 PM
