BRAKE FLUID LEAK
Old Oct 14, 2007 | 06:12 PM
pinks11's Avatar
Default BRAKE FLUID LEAK
I havent drove my car for a day, and when i came home and checked it out there was a puddle brake fluid all over the ground. The puddle was under the right axel/ wheel. I checked the master cylinder and all the fluid is gone. I just replaced the brake pads and resurfaced the rotors, but I did not change the calipers. Do you guys think that this could be a cause of the caliper?? Or Maybe the brakeline is cracked?? Please let me kno, I am planning to do a light overhaul of the car, New Axels alignment and hopefully new calipers over the next week.
Old Oct 15, 2007 | 10:05 AM
B16B_coupe's Avatar
HRD PKR
Default Re: BRAKE FLUID LEAK (pinks11)
A>well go to that side of the car and check the brake line.. see if its busted.
B>You might of messed up the piston in the caliper if u werent careful/knew what your doing
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
91integraLSVTEC
Jul 25, 2009 07:09 PM
St3v3
Jan 2, 2008 04:52 PM
pinks11
12
Oct 17, 2007 04:08 PM
92integraVTECgsr
Jun 7, 2006 02:57 PM
