Converted to rear disc. Leaking at prop valve. Any ideas?
Old Oct 14, 2007 | 06:07 PM
Dublin's Avatar
Default Converted to rear disc. Leaking at prop valve. Any ideas?
Back in August, I converted my 98 EX Coupe from rear drum to GSR rear disc. Along with the rear discs, I also installed Goodridge steel braided lines, a 1" master cylinder, and as far as I know, an Si proportioning valve. (the proportioning valve was picked up from a junk yard, but the guy wasnt sure if it was an Si or all wheel disc CRV). The system is filled with Motul RBF 600.
Noticing the fluid level low, I found a leak at the proportioning valve, at line #1 and #5 (#1 being the furthest left, aprox. 11 o' clock, and moving clockwise, and #5 being at aprox. 4 o' clock). Both of these lines are the ones connected to the master cylinder. All of the hard lines are still the stock originals, and tightened to the point that they feel like they wrench will start rounding off the bolt if tightened any more.
I am looking for any insight or suggestions to a possible remedy.
Thanks.
Old Oct 14, 2007 | 06:44 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: Converted to rear disc. Leaking at prop valve. Any ideas? (Dublin)
teflon tape is your friend
Old Oct 14, 2007 | 06:48 PM
trev0006's Avatar
* B A N N E D *
use loctite
kantspell
Sep 30, 2011 07:53 AM
b18ccivics
Aug 20, 2006 06:22 AM
EGhatched
10
Mar 31, 2004 08:45 AM
civic dx
Jun 25, 2003 12:38 AM
arcsec
Nov 23, 2002 11:55 PM
