CEL codes 72 and 74
Well the codes states that cylinders 2 and 4 are misfiring. I have searched and read some topics that poeple had with this problem. Some have chipped/broken valves, others had loose wires but was wondering if any other ideas are out there.
Please post up if anything that I should do. I bought some new plugs and still having the same problems. The rotor is new and plugs look fine. Wires are on tight. Inside the cap looks fine. Anything other suggestions before I need to take off the head and check which I want to be my last resort. Compression will be done tomorrow for sure.
New pistons and rings put in 300 miles ago. Everything was running fine for the couple of days and last night under normal driving conditions car suddenly drives like poop and these 2 CEL codes popped up.
Car runs/sounds like a WRX. Idles rough and sometimes dies because it idles so low. The motor/car shakes while in idle because of the misfiring. It drives real sluggish also.
Modified by dcdcdc at 7:20 AM 10/15/2007
well got the compression tested and cylinders 1, 3, and 4, were okay at 200psi. bad news is the cylinder 2 has zero compression. any suggestions or any one ever experience this?
where are all the suggestions.
MrXclusivE
11
Jan 14, 2010 01:15 PM
GRASSROOTS_HONDA
Feb 6, 2007 04:30 AM
