92 Eg Hatch "when the door opens" no beep beep beep
Old Oct 14, 2007 | 05:33 PM
likwidchz's Avatar
Default 92 Eg Hatch "when the door opens" no beep beep beep
Anyone happen to know why when the door opens there isnt any beep beep beep?
I am not sure what i forgot to wire up or mixed up any help would be fantastic.
Thanks.
Old Oct 14, 2007 | 05:43 PM
cimo463's Avatar
Default Re: 92 Eg Hatch "when the door opens" no beep beep beep (likwidchz)
Now I am not sure with you car...but I no mine (97 EJ6) only beeps if the key is in the ingnition....Other than that it never beeps
Old Oct 14, 2007 | 05:53 PM
95whitehatch's Avatar
check your fuses...also when you open you door is dome light on, and when you close it does it go off----> if not check your and make sure you door pin is fine
Old Oct 14, 2007 | 06:08 PM
likwidchz's Avatar
Ill have to re assemble parts of the intereor, ill check the fuses, exactly which one?
as for the dome light ill connect a multimeter to it and make sure it gets 12 volts when the door pin is grounded since the door pins arnt in yet.
any other suggestions?
hackbatch
May 11, 2025 12:15 PM
overdriiive
Dec 26, 2009 07:35 PM
teamV eg
Feb 19, 2007 09:02 AM
4DRmafia
10
May 29, 2004 07:46 PM
