hood clearance
Old Oct 14, 2007 | 05:28 PM
spiderhatch's Avatar
Default hood clearance
Dropped my ls\v-tec in and engine to high. any tips for shutting my hood.
Old Oct 14, 2007 | 05:35 PM
97Ej6mike's Avatar
Are you sure the motor is in properly? Ive never heard of that being an issue with B-series. Are you using the stock hood or an aftermarket, such as a carbon fiber one?
Old Oct 14, 2007 | 05:38 PM
Default Re: (97Ej6mike)
well i have two i have a stock one and i have a cervinis ss hood. i haven't tried to shut the hood yet cause im not done with it but i put a pipe across fender to fender and its not flush.
Old Oct 14, 2007 | 05:42 PM
serio_ENDLESS's Avatar
check your motor mounts and back bracket did you use a gsr rear bracket?
what head did you use?
97Ej6mike's Avatar
Default Re: (spiderhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiderhatch &raquo;</TD></TR><TR><TD CLASS="quote">well i have two i have a stock one and i have a cervinis ss hood. i haven't tried to shut the hood yet cause im not done with it but i put a pipe across fender to fender and its not flush.</TD></TR></TABLE>
Well, when you do get done, An OEM hood should not have a problem closing over any 92-00 civic with any b18. Only issues ive seen are with H22's, or Aftermarket hoods. For this LS/V build, what head did you put on?
Old Oct 14, 2007 | 06:03 PM
96 gsr
Old Oct 14, 2007 | 06:12 PM
Hybrid_Ej188's Avatar
yes as he said check you motor mounts....should of dropped right in
Old Oct 14, 2007 | 06:20 PM
Default Re: (Hybrid_Ej188)
thanks maby i will just test fit the hood before i go any farther
Old Oct 14, 2007 | 07:15 PM
fatpride111's Avatar
i had hood clearence problems with my stock gsr in my eh2, and the only problem was my hood latch was set too low. got a wrench, adjusted the 2 bolts, and punched the dents back in from my hood smashing my valve cover, and i was good to go. never had a problem with it since then
Old Oct 14, 2007 | 07:25 PM
sycotickid's Avatar
Default Re: (fatpride111)
around here every one ither spaces up the rear in between the hinges in hood with washers or spacers........or they cut a piece out of the hood just in the lower support braces and it dosent seeem to change the rigidity in the hood
lude98SH
Aug 16, 2006 08:28 PM
markysparky
19
Jan 1, 2006 03:20 AM
jdmjeff
Jan 19, 2005 04:09 PM
baphomet
Aug 6, 2003 05:56 PM
HotRodDelSol
Jun 14, 2003 07:01 PM
