problem starting...clutch? starter?...SENSORS!?!
Old Oct 14, 2007 | 02:04 PM
Honduh Uhcord's Avatar
Default problem starting...clutch? starter?...SENSORS!?!
ok so recently i replaced my clutch master and slave cylinders...my cars clutch pedal is very tight and feels mechanical more than fluid...the car isnt sensing that the clutch is depressed making me unable to turn the car over(could be another problem...either way car wont start)...so i had me and my friend try roll starting it(put in gear...put the clutch in...roll it...pull up on the clutch...and bam it started up) so it was running and driving and i could shift...but once i turned it off getting it back on was a no-go...i have no more ideas on what it is...I NEED A CAR!?!? please help
Old Oct 14, 2007 | 02:15 PM
TheMuffinMan's Avatar
He knows where you live!
bleed the clutch line?
clutch start switch?
Old Oct 14, 2007 | 02:33 PM
Default Re: (TheMuffinMan)
wheres the clutch start switch?? and what will bleeding it more do??? thanks for the ideas
Steven Gilner
Sep 26, 2013 10:20 PM
Nataku
Oct 19, 2007 11:39 AM
rough_draft
Feb 8, 2005 04:24 PM
deviant1
May 7, 2003 11:26 AM
TEGPOWER44
Dec 16, 2002 10:11 AM
