92 Civic won't start until engine light turns off....
Old Oct 14, 2007 | 01:38 PM
Forgotten_0182's Avatar
Default 92 Civic won't start until engine light turns off....
Problem....... 92 civic 130,000 thousand miles, been a great car no major problems engine wise, just normal stuff ie. starter, slave cylinder, alternator.
I turn igniton to acc and the engine light comes on, but won't go off, and the car will not start it will turn over but thats it. After a few minutes, it varies from 1 or 2 minutes al the way up to 10, you hear the fuel pump whirl and the engine light goes off and the car will start no problem.
I jumped the fuel pump, so it funs on acc all the time, still not starting; the engine light still on by the way. I check the Main Relay, not that still same thing. Ive tested the Map sensor and checked all fuses that I could think of.. My next thought was the ECU, but before i go and buy another one i was hoping someone else had any idea about what it could possibly be.
The only problem with the engine is that it has low compression and needs a new set of rings, other than that its all good...
Let me know...
Old Jan 23, 2008 | 01:01 PM
AntBotNo5's Avatar
Default Re: 92 Civic won't start until engine light turns off.... (Forgotten_0182)
You need to find out what code is causing the check engine light to come on.
use this thread:
https://honda-tech.com/zerothread?id=682412
Old Jan 23, 2008 | 01:09 PM
wangkata's Avatar
check ur CEL what code? check this out....
https://honda-tech.com/zerothread/1901557
ballbuster4u
17
Sep 20, 2019 07:01 AM
mkhalid8
Jan 31, 2015 01:11 PM
electrones
Honda Civic (2006 - 2015)
Oct 24, 2013 03:03 AM
osbunjosh
12
Mar 3, 2013 12:20 PM
Timmyflys
Nov 29, 2006 04:26 AM
