Hood dents from fallin accorns
Old Oct 14, 2007 | 10:49 AM
Si_chRis's Avatar
Default Hood dents from fallin accorns
So I leave my car parked at my house while I'm away at college and I keep a car cover on it. So when I came home this weekend...I found about 5 tiny dents on my hood ...So heres the thing...there is a big *** tree in my yard and accorns fall from it and that is obviously the cause of the dents.
I'm wondering if the dents can be pulled by like a paint less dent remover place?...or a body shop?
I don't have pics of the dents but they're the tiny kind which you can only see up close and at an angle...prolly the size or half a dime.
Any help I appreciate.
Modified by Si_chRis at 8:50 PM 10/14/2007
Old Oct 14, 2007 | 04:59 PM
Si_chRis's Avatar
Default Re: Hood dents from fallin accorns (Si_chRis)
Anybody have experience with dent wizard?
Old Oct 14, 2007 | 05:24 PM
siblues's Avatar
I have had dent wizards do some dings for me and they did an amazing job couldnt even tell they were there and I knew where they were.You will have problems if they are creased or they cant get to them because the hood frame is in the way
Old Oct 14, 2007 | 05:40 PM
Si_chRis's Avatar
Default Re: Hood dents from fallin accorns (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I have had dent wizards do some dings for me and they did an amazing job couldnt even tell they were there and I knew where they were.You will have problems if they are creased or they cant get to them because the hood frame is in the way </TD></TR></TABLE>
The dents are very small...not noticeable unless you are up close and look at an angle...I don't think they're creased...I haven't looked on the underside to see if the hood frame is in the way though...
How much does dent wizard usually charge roughly?
Old Oct 14, 2007 | 08:07 PM
siblues's Avatar
Last time I had them done was 75-100 per panel with two or three dents if you have more they will charge a little more.
Old Oct 15, 2007 | 07:27 AM
Si_chRis's Avatar
That sounds not too bad at all...I'll look into it.
Thanks.
aZnPIGbOi
Paint and Body
Aug 4, 2007 10:34 PM
EJ8VTEC
Paint and Body
May 22, 2007 06:18 AM
96lewd
Jan 29, 2005 04:47 AM
stilzx61
Oct 28, 2003 07:58 PM
Duck Sauce
Dec 22, 2001 02:38 AM
