Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Can the headlights on a 07 civic ex be made to turn off with the ignition?
Old Oct 14, 2007 | 08:20 AM
bvardaro's Avatar
Default Can the headlights on a 07 civic ex be made to turn off with the ignition?
I own a 2007 Civic EX, I am used to having the lights go out with the ignition from previous cars I have owned. At night I park in the garage and often forget to shut the headlights off. I leave the keys in the ignition and that chime warning over rides the headlamp on warning. Consequently i wake up to a dead battery. is there any way to program the lights to go out when the ignition is turned off?
Old Oct 14, 2007 | 10:36 AM
fg2si!kid's Avatar
New User
Default Re: Can the headlights on a 07 civic ex be made to turn off with the ignition? (bvardaro)
the only way to do something like that would to rewire the head lights and unless you have experince with auotmotive wireing or electonics also you would need wireing dighrams for your head lights and ingtion system sounds like way to much work to me you best bet would be just to remember to turn you lights off
Old Oct 14, 2007 | 05:23 PM
Tyte-S's Avatar
Default Re: Can the headlights on a 07 civic ex be made to turn off with the ignition? (fg2si!kid)
If youre really determined to re-wire te light to go on with the ignition. You can get both wiring diagrams from http://www.alldata.com
x4thGenCafe
Jan 5, 2008 08:54 PM
mystyc
Jan 27, 2005 02:17 PM
AznJohn33
May 25, 2004 10:50 PM
katb16vo
Apr 7, 2004 11:37 AM
