GSR Cluster Question
Old Oct 13, 2007 | 08:33 PM
gursh d's Avatar
Default GSR Cluster Question
Is there a difference between the cluster's in OBD1 GSR's and OBD2 GSR's?
Asking because I have a CRX with a 94-95 JDM OBD1 B18C motor (Y80 w/LSD tranny) and need a GSR cluster...just wanting to know if I need one from a certain year (OBD specific) OR if any GSR cluster would do.
If it matters, I got the OBD0 to OBD1 conversion harness from Rywire and the VTEC subharness.
TIA
Old Oct 13, 2007 | 10:35 PM
snowracer69's Avatar
Default Re: GSR Cluster Question (gursh d)
im havin the same problem but i have a b17 with the computer(chipped also) but im having trouble with the wireing mods from the stock crx to the b17 motor.
Old Oct 14, 2007 | 12:20 PM
gursh d's Avatar
anybody know?
Old Oct 14, 2007 | 12:42 PM
BlueIntegraBoy's Avatar
It doesn't matter what year cluster you have for your car, it matters how you wire it up.
https://honda-tech.com/zerothread?id=1053318
Old Oct 14, 2007 | 01:17 PM
TURBODC4TEG's Avatar
Default Re: GSR Cluster Question (BlueIntegraBoy)
far as i know they are same except for the newer gsr cluster will have the driver key light on there. i guess thats what its called lol
Old Oct 15, 2007 | 08:37 PM
B.J.'s Avatar
Not sure
Old Oct 16, 2007 | 05:56 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gursh d &raquo;</TD></TR><TR><TD CLASS="quote">Is there a difference between the cluster's in OBD1 GSR's and OBD2 GSR's?
TIA</TD></TR></TABLE>
since you're going to be rewiring the cluster either way, it won't matter. the wiring IS different between 94-97 and 98+, so be sure you follow the wiring instructions for the correct cluster.
redclaw05
May 28, 2008 03:43 PM
gursh d
Aug 9, 2007 06:32 AM
JDMITRTURBO
Aug 8, 2006 05:05 AM
v-tec maz
May 10, 2006 07:36 AM
