left turn signal bulb keeps on blowing out
Old Oct 13, 2007 | 05:54 PM
civiccoupe94's Avatar
Default left turn signal bulb keeps on blowing out
its the front drivers side signal (where the corner light is) on a eg coupe. the signal bulb keeps on blowing out after a month or so, and i have to replace it, but the running lights part of the bulb always stay good. is this a wiring issus such as too much voltage or something else?
the bulbs arent expensive, but its just annoying to change them / have the blinkers blink very fast when it burns out.
thanks
Old Oct 14, 2007 | 12:32 AM
ek-g6's Avatar
Default Re: left turn signal bulb keeps on blowing out (civiccoupe94)
you may have a short check in your wiring.
Old Oct 14, 2007 | 05:27 AM
keep_up's Avatar
Default Re: left turn signal bulb keeps on blowing out (ek-g6)
i just started a appreentichip at a GM dealership and there was this exact problem.
we figured it out and it was the pins in the lightbulb socket were bent. so check out the pins and make shure there not out of place or bent.
Azavala
Apr 8, 2016 02:14 PM
andyisftw
May 14, 2010 10:55 AM
DC4R27
Mar 23, 2007 10:09 PM
eg8000rpm
Apr 27, 2005 12:37 PM
RedHackBatch
Jul 6, 2004 09:39 PM
