Low beam went out, but hight beam is OK
Old Oct 13, 2007 | 05:05 PM
graywzc's Avatar
Default Low beam went out, but hight beam is OK
Both the two front low beam went out, but the high beam still works.
However, I only see one bulb.
Any possible cause of this kind of problem?
Thank you~
Old Oct 13, 2007 | 05:08 PM
LilDrunkenSmurf's Avatar
check your fuses under the dash
Old Oct 13, 2007 | 05:13 PM
skcivic4life's Avatar
Default Re: Low beam went out, but hight beam is OK (graywzc)
cuz you only have one bulb per headlight, change the bulb and see if that helps mabey both low beams burnt out at the same time?, if not it would be a fuse.
Old Oct 13, 2007 | 05:28 PM
ekb16's Avatar
if its just 1 bulb then its low and high beam together..just get new bulbs and u should be good to go.
Old Oct 13, 2007 | 05:55 PM
nonvtec92's Avatar
Default Re: (ekb16)
this happened to me about a month ago when i hit a deer....
same bulb for high and lows, but two different filaments.
take our a bulb and check it out...
time to buy new ones.
mrbassman001
Jan 7, 2011 10:22 AM
shocker911
Mar 2, 2010 01:53 PM
invision
Apr 3, 2008 05:19 PM
stupidsn87654
Lighting
Sep 8, 2007 07:27 PM
UntouchableEX
May 19, 2005 07:56 AM
