Check engine light problem?
Old Oct 13, 2007 | 04:37 PM
ef8cybercrx's Avatar
Default Check engine light problem?
I have a 92 eg hatch with a 95 D16Z6 motor. When I turn the key to the "on" position and the fuel pump is priming, the check engine light doesn't come on. Isn't it supposed to come on and then go off?
Does that mean my check engine light is disabled?
Old Oct 13, 2007 | 04:49 PM
thesmogman's Avatar
Default Re: Check engine light problem? (ef8cybercrx)
If your car run's fine...means the ecu is ok.
You probably just need to replace the bulb.
TeamSumner
Sep 29, 2014 05:14 AM
thunderboy
Mar 9, 2008 09:49 PM
jdium
Mar 4, 2006 10:13 PM
RAB
Mar 9, 2003 10:00 PM
