Help - Installing pistons, rings, and rods
If I want to install new pistons, rings, and rods, do I have to take the engine out of the car to do this? I hear that you can do this from underneath, after removing the oil pan and stuff. How much does a shop usually charge for installing pistons, rods, and rings? Thanks for your help
it's a lot easier with the engine out of the car and on a stand. you cannot pull pistons out from the bottom. you need to measure bearing clearances and ring gaps to properly do it.
complete bottom end walk thru
https://honda-tech.com/zerothread?id=1924483
crxrider07
Mar 14, 2009 10:44 AM
Jeanious
Dec 4, 2007 12:41 PM
