buddy club spec 4 head package
Old Oct 13, 2007 | 12:03 PM
bjones's Avatar
Default buddy club spec 4 head package
http://passwordjdm.com/Buddy-C....aspx
looking to do rebuild on my gsr this winter, was looking at the buddy club spec 4 head package and was wondering if anyone has had any experience with these, any pros and cons, thanks.
Old Oct 13, 2007 | 12:44 PM
doood's Avatar
been there done that
Default Re: buddy club spec 4 head package (bjones)
rebuild the block while you're at it. they like more compression than stock. 11:1+
Old Oct 13, 2007 | 12:49 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: buddy club spec 4 head package (doood)
Pretty penny thats for sure. Any reason why your picking Buddy Club intstead of Skunk2?
Old Oct 14, 2007 | 05:08 PM
bjones's Avatar
Default Re: buddy club spec 4 head package (HondamanXxX)
no not really jus lookin around at my options
Old Oct 14, 2007 | 06:45 PM
all-mtr-teg's Avatar
I think that is overpriced by a couple hundred dollars. You can probably get it for under $1000 if you shop around. Or maybe just get the RM package for that price.
Old Oct 14, 2007 | 08:18 PM
nokturnal_munkeeboy's Avatar
hey there you have a question bout bc4 head package, i bought the package myself i jus havent put the cams in yet becuz i had to smog my car while back now i pass smog. i tried to put the cams in but it didnt start in my car becuz i was usin my stock ecu, you have tune ur car for those cams like with hondata or with other engine management, but i think worth tryin it out , if it doesnt work for you , you can alway sell the cams and keep the valvetrain. but i will let you know when i put those cams in.
Old Oct 15, 2007 | 08:30 AM
bjones's Avatar
Default Re: buddy club spec 4 head package (nokturnal_munkeeboy)
thanks ya let me know
Old Oct 15, 2007 | 11:25 AM
HpRevolution's Avatar
I'm using the spec 4 package, you'll need higher compression for them. For me they work great all around.
Old Oct 17, 2007 | 08:46 AM
Default Re: buddy club spec 4 head package (HpRevolution)
i'm runnin bout 11:5-11:8 on my gsr
Old Oct 17, 2007 | 09:16 AM
bjones's Avatar
what pistons you running?
Old Oct 17, 2007 | 09:44 AM
ABCVTEC's Avatar
Thats actually a pretty damn good deal for BC Camshafts, cam gears, valves and retainers. I'd say go for it. With Buddy Club you know what you're getting.
Old Oct 17, 2007 | 10:01 AM
Default Re: buddy club spec 4 head package (ABCVTEC)
That is not a good deal, that is like 200-300 overpriced. You can get this package
http://cgi.ebay.com/ebaymotors...ZWD1V
which inluded BC4 cams, cam gears and dual valvesprings for 750 shipped, and get some RM or BC retainers for like $150-200.
$1200 is not a good deal, even if you bought everything seperate you could still find it cheaper than $1200. You're a fool if you pay that much.
Old Oct 17, 2007 | 10:38 AM
dizzzane's Avatar
Default Re: buddy club spec 4 head package (all-mtr-teg)
That does seem pricey.........
Old Oct 17, 2007 | 11:23 AM
Default Re: buddy club spec 4 head package (dizzzane)
passwordjdm and inline4 are a few of the highest priced shops. If you shop around and buy things seperate, you can get BC4 cams for 450-500, cam gears for 160-170, VS for 180-200, rets. 150-200. Even seperate that's less than $1100. So how is a $1200 'Package Deal' a good deal?
Old Oct 17, 2007 | 11:39 AM
ABCVTEC's Avatar
I stand corrected.
Old Oct 17, 2007 | 12:16 PM
Don't get me wrong, BC makes great products, i run BC3 in my DD, but 1200 for a so called "packaged deal" that's rediculous. For that much money you can get a RM package and make more power for less also.
Old Oct 17, 2007 | 12:39 PM
i'm runnin jdm itr os pistons with hi compression valvetrain
Old Oct 17, 2007 | 02:29 PM
What block and what head, both gsr?
Old Oct 17, 2007 | 03:14 PM
i got a gsr block and head with 13.1 cp pistons. it starts up rough, but idles good when its warmed up
Old Oct 17, 2007 | 06:06 PM
gsr head and block
Old Oct 17, 2007 | 06:53 PM
Assuming no milling or decking and your running a stock HG, your at around
11.7-11.8:1 CR. Great CR for BC4 when tuned
Old Oct 17, 2007 | 07:14 PM
right now i have problem now. i have oil leak in my spark plug area
Old Oct 18, 2007 | 06:28 AM
Are the threads saturated or just the tips. If the threads are saturated most likely you need to replace your spark plug grommets. If its just the tips, maybe you rings
Old Oct 18, 2007 | 07:27 AM
the whole plug are submerge in oil, i bought new plugs and grommets and processin to take my car back to the shop they can fix the problem hard part is that i dont have money to get my car tow over there.
Old Oct 18, 2007 | 07:45 AM
Just change the grommets yourself, its as easy as changing the vavle cover gasket.
