car wont stay on , was running fine
Old Oct 13, 2007 | 11:08 AM
alexsracing's Avatar
Default car wont stay on , was running fine
Im on hondata s300, was driving the car for 2 days , then it stated just reading from the 0 column while datalogging and would turn off from being rich.
I have tryed a motorola map, then an aem 3.5map, and even tryed to turn it on with a oem map sensor, all the same outcome.
I have also tryed switching to my old uberdata ecu and the same.
with a volt meter I get 5.00v from the power to map using the map ground for ground, and the signal read at the ecu with key on is 1.67v
what could be wrong???
and if I try to keep it on by just holding the gas pedal floored it is bearly on and threw a tps code, that it never threw before
Ill get tps readings right now
Old Oct 13, 2007 | 11:22 AM
my tps reading closed is 1.10v and fully open is 4.98v but was running fine for 2 days
Old Oct 13, 2007 | 03:14 PM
the 1.67v reading from the map is from the eam 3.5bar with engine off and key
front
the oem map with key front engine off is 0.12V signal
Modified by alexsracing at 8:11 AM 10/14/2007
Old Oct 14, 2007 | 07:12 AM
bump
Old Oct 14, 2007 | 01:17 PM
up
Old Oct 15, 2007 | 05:43 AM
ttt
carlos8
36
May 4, 2014 05:42 AM
boostedcivicsir
Jul 24, 2007 06:17 AM
ek9 ferio
May 31, 2005 07:49 PM
abmerop18
Jan 19, 2005 07:08 AM
dannydos
Dec 12, 2004 06:17 AM
