SWAP INFO.
i started my frankenstein.. B18C6 (JDM TYPE R)LONG BLOCK AND B16B HEAD MOTOR. iM WONDERING IF ANYBODY KNOWS WHERE I CAN GET SOME GOOD CAMS.. PREFEREABLY A TYPE R CAMS THAT ARE LEGIT. i see some online but im not confident that they're the same specs. i PRETTY MUCH NEED THE WHOLE HEAD ASSEMBLY. (valves, sprockets, cams, timing specs) i JUS BOUGHT THE HASPORT MOUNTS. ANYBODY KNOW IF THOSE ARE MORE RELIABLE THAN ANY OTHER LEADING BRAND.??
every engine has a number after..thats wat makes it usdm or jdm././
http://www.superhonda.com/tech....html refere to that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonsinglecam »</TD></TR><TR><TD CLASS="quote">every engine has a number after..thats wat makes it usdm or jdm././
I think you need to read your list a little closer there bro LOL
To make this B16 head better than the B18c6 head (which is EDM), you'll need to at least mildly port it, same with the intake manifold (if you opt for a stock B16 one). Then the cams (at least ITR) and valvetrain are up to you.
You probably already knew this, all Type-R heads and intake manifolds are ported from the factory by hand, the whole engine is handbuilt. They do this with any Type-R (dc2, dc5, ek9, ep3, Accord Type-R, NSX-R, and the new Civic Type-R).
Modified by Rok_Stok at 10:05 AM 10/16/2007
B18C6
* VTEC
* Found in:
o 1998-2001 Honda Integra UK and Euro Spec Type R
* Type: 1.8 litre 16v DOHC 4 cylinder in-line
* Displacement: 1797 cm³
* Compression: 11.1:1
* Air intake diameter: 70mm
* Bore: 81 mm (3.189")
* Stroke: 87.2 mm (3.433")
* Rod Length: 137.9 mm (5.429")
* Rod/Stroke Ratio: 1.58
* Power: 190ps/139kW/187hp (SAE net hp) (139 kW) @ 7900 rpm & 131 ft·lbf/178 Nm @ 7300rpm
* Red-line: 8400rpm
* Transmission: S80 w/LSD
Source: http://en.wikipedia.org/wiki/Honda_B_engine
I'm pretty sure you're misinformed...
* VTEC
* Found in:
* Red-line: 8400rpm
gingboy
Aug 31, 2001 10:50 AM
