Camber and Toe
Old Oct 13, 2007 | 08:45 AM
EK_B's Avatar
Default Camber and Toe
Do these specs look ok for a 2" drop? This is after I got an alignment.
Toe:
0.06Front Left 0.05R Front Right
0.11 Rear Left 0.06 Rear Right
Camber:
-0.8 Front Left -1.1 Front Right
-2.3 Rear Left -1.7 Rear Right
HERE ARE THE BEFORE SPECS:
Toe:
-0.23Front Left -0.21R Front Right
0.35 Rear Left -0.21Rear Right
Camber:
-0.7 Front Left -1.1 Front Right
-2.1 Rear Left -1.8 Rear Right
Modified by EK_B at 10:25 AM 10/13/2007
Old Oct 13, 2007 | 08:54 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Camber and Toe (EK_B)
Your rear left is going to chew itself up. I'd be a lot happier if my specs were closer from tire to tire
Old Oct 13, 2007 | 08:57 AM
EK_B's Avatar
Ah crap, what do I do about this? And is it because of the big camber difference?
Old Oct 13, 2007 | 09:26 AM
EK_B's Avatar
I added the before specs for a comparison.
Old Dec 24, 2007 | 06:12 PM
thirsk66's Avatar
Default Re: (EK_B)
hey whats the diffrenece betweeen a camber kit and a toe kit for the rear of my 1997 honda civic? im so lost?
Old Dec 24, 2007 | 06:21 PM
Padawan's Avatar
Darth ModerVader
It doesn't look bad to me. You could probably bring the left rear camber a bit closer using a washer/shim, but otherwise it should be fine.
EK_B
Suspension & Brakes
Oct 15, 2007 11:34 AM
TurboEM1
Suspension & Brakes
10
Mar 31, 2006 05:12 AM
DAMCOOLDAV
Aug 16, 2004 08:30 AM
AzntaggeR
18
May 1, 2004 03:21 AM
01CWITR
Aug 6, 2002 05:32 PM
