Suspension & Brakes Theory, alignment, spring rates....
Cupping Tires. What could be the cause?
Old Oct 13, 2007 | 08:37 AM
JDMhatchback20's Avatar
Default Cupping Tires. What could be the cause?
My steering wheel started to shake at high speeds, so I went to the tire place to have my wheels rotated and rebalance.
They let me know that my tires (Kumho Ecsta SPT -- 215/40/16) are starting to cup ( highs and lows on inside of tire). They said my lowered car was probably the reason for it. However, I've lowered a few cars and never had this problem.
My current set up is H&R Sport Springs with stock shocks and no camber kit. Is this spring too much for my stock shocks? Causing my car to hop and cup the tires? Or would my shocks just be going out?
I've had this setup for about a year. The stock shocks are more than likely the original ones from 2000 that have about 120,000 miles on them.
Let me know your thoughts!
Thanks!
Old Oct 13, 2007 | 08:45 AM
PIC Performance's Avatar
Default Re: Cupping Tires. What could be the cause? (JDMhatchback20)
Not enough air pressure maybe.
Old Oct 13, 2007 | 09:07 AM
ThoseDarnKids's Avatar
Default Re: Cupping Tires. What could be the cause? (PIC Performance)
I'd bet those shocks are worn and are the cause. Cupping can be caused by out of balance wheels or bad shocks, among other things. Check your shocks to see if there's fluid leaking out of them.
Old Oct 13, 2007 | 04:55 PM
Targa250R's Avatar
be professional
What are your current alignment specs?
Old Oct 13, 2007 | 11:09 PM
egb18c5's Avatar
Default Re: Cupping Tires. What could be the cause? (ThoseDarnKids)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThoseDarnKids &raquo;</TD></TR><TR><TD CLASS="quote">I'd bet those shocks are worn and are the cause. Cupping can be caused by out of balance wheels or bad shocks, among other things. Check your shocks to see if there's fluid leaking out of them.</TD></TR></TABLE>
i agree
Old Oct 14, 2007 | 09:06 AM
EK_B's Avatar
Guy at Discount Tire told me cupping is due to unbalanced wheels.
Old Oct 14, 2007 | 05:35 PM
verycleanhatch's Avatar
damn can tires cup because of bad shocks? i have bad shocks right now....
I thought when i had cupped tires was because i did not have an alignment because i remember two of my tires were cupped and i believe it was the rear tires. The rears i did not get an alignment on.
Old Oct 14, 2007 | 07:09 PM
KaBlookie's Avatar
Default Re: Cupping Tires. What could be the cause? (verycleanhatch)
First order of business, don't take your car to that shop anymore...I freakin' hate it when people blame car problems on the fact that it's modded just cause they have something against kids with modded cars. Your cupping isn't because the car is lowered...it's likely because of one of the above reasons...alignment, tire pressure, unbalanced tires, or bad dampers.
Check those out and take your car somewhere else. If they don't like people with modded cars, they're not going to do their best working on the car.
Old Oct 15, 2007 | 06:01 PM
audsyn's Avatar
I had cupped/wavy tires on the rear caused by worn shocks. The mechanic said it was a common problem, fwiw.
Old Oct 15, 2007 | 06:10 PM
Tyson's Avatar
Default Re: Cupping Tires. What could be the cause? (audsyn)
shocks for sure.
Old Oct 15, 2007 | 07:59 PM
supracrx's Avatar
x2
shocks
Old Oct 16, 2007 | 06:22 PM
-JAWSHUA-'s Avatar
sounds like your shocks are taking a **** on you. you might wanna check those out.
Old Oct 17, 2007 | 04:21 AM
I got a set of KYB AGXs ready to go in.
Thanks guys
Old Oct 20, 2007 | 08:05 AM
jcochran's Avatar
Default Re:
Ive had a couple people tell me cupped tires are because of lack of rotation. not sure if its true.
bluestd
May 23, 2010 10:05 PM
JDMhatchback20
12
Oct 14, 2007 09:38 AM
blackriceman
Suspension & Brakes
Mar 6, 2007 12:43 PM
GoLowDrew
Sep 2, 2004 03:59 PM
gofastgsr
Feb 4, 2004 06:28 PM
