system too rich too lean
Old Oct 13, 2007 | 08:07 AM
charlie0801's Avatar
Default system too rich too lean
so ive had this code now for a couple of months and heres what ive changed as a result of that
new primary o2 sensor
new dizzy rotor and cap
new wires
new plugs
whats else could it be? its really starting to **** me off
Old Oct 13, 2007 | 08:12 AM
kardal86's Avatar
Can be a bad motor> blow by bad compression, or poorly adjusted valves. Also a problematic fuel system.
Old Oct 13, 2007 | 08:56 AM
Hawkze_2.3's Avatar
Default Re: system too rich too lean (charlie0801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlie0801 &raquo;</TD></TR><TR><TD CLASS="quote">so ive had this code now for a couple of months and heres what ive changed as a result of that
new wires
new plugs
whats else could it be? its really starting to **** me off</TD></TR></TABLE>
Could be the secondary 02 sensor or the catalytic converter...
Old Oct 15, 2007 | 08:22 AM
andre809_lude's Avatar
check your EGR ... my was runing lean because the EGR valve was stuck... the mixture was not diluted by the exhaust gas throught the EGR like it was supposed to be...
see if that makes a difference.
Old Oct 15, 2007 | 08:24 AM
lude98SH's Avatar
Default Re: system too rich too lean (andre809_lude)
are you running too rich or too lean ? Or both ?
Old Oct 15, 2007 | 08:25 AM
lude98SH's Avatar
Default Re: system too rich too lean (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Could be the secondary 02 sensor or the catalytic converter...</TD></TR></TABLE>
The secondary is just used to monitor catalyst efficency. The primary is the only thing that would affect mixture. Unless your saying the cat isnt cleaning up the HC,CO and NOx.
Old Oct 15, 2007 | 09:11 AM
Hawkze_2.3's Avatar
Default Re: system too rich too lean (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">
The secondary is just used to monitor catalyst efficency. The primary is the only thing that would affect mixture. Unless your saying the cat isnt cleaning up the HC,CO and NOx. </TD></TR></TABLE>
Yeah, I'm expert on OBD2, but wouldn't a bad cat or secondary O2 be able to cause a code like that?
Old Oct 15, 2007 | 05:45 PM
prelude_h22vtec's Avatar
so you're obd2? plenty of things can cause rich. whats the fuel trim? probably negative...run a scan with a good scan tool. check all things that adjust fuel. check your FPR. check the MAF values.
Old Oct 15, 2007 | 05:46 PM
lude98SH's Avatar
well a bad cat may show more hydrocarbon output, but the actual mixture would be unaffected. A bad secondary wouldnt affect mixture, it would only throw code i believe, correct me if im wrong though.
Old Oct 15, 2007 | 05:50 PM
you're right, the secondary just checks to make sure you're not polluting.
lopa
Apr 11, 2013 06:35 AM
cheesyrex
Nov 30, 2009 02:23 PM
98IntegraLSNonVtec
Aug 4, 2006 09:18 PM
feelo777
May 14, 2005 08:12 AM
Tegra
Jan 27, 2003 05:47 PM
