driver side window installation
has anyone done this before?
im having problems i installed the window but when i roll it up the side closest to the door handle is all the way up and everywere else is about 1 inch from the top.
i havent touch a thing since i removed it and it worked before some kids broke into my car
Roll the window almost all the way down. Leave a little bit above....just enough to grab on to.
Remove the speaker from the door. When you pull that out you should be able to see the track for the window...the front track at least. I was having the same problems....
Now grab the window that you left up and try sliding it back....towards the rear of the car....if it does slide back...slowly crank the window up...using your hand through the speak pod...make sure the window goes into that front track...
That's what happened to my window before...you're problem might be something else....
Let me know how it goes.
crxaddikt
17
Jan 13, 2015 04:04 AM
