radiator
Old Oct 13, 2007 | 07:24 AM
bless341's Avatar
Default radiator
sup guys i have a 90 Si with a ls in it. Problem is that i just changed my old crusty radiator yesterday and the car doesnt want to warm up all the way. I noticed that the previous owner wired the fan so it would be on all the time. Is there a way to make the fan work with the thermostat?
Old Oct 13, 2007 | 07:42 AM
KrenzyRyan's Avatar
Default Re: radiator (bless341)
Yes, you have to somehow wire it to the Thermoswitch.
Hopefully someone can help find you a wiring diagram or something, because I don't have anything on hand...
bump for your post!
Old Oct 13, 2007 | 08:23 AM
bless341's Avatar
where is the thermoswitch located?
Old Oct 13, 2007 | 08:33 AM
slowcivic2k's Avatar
Default Re: (bless341)
Its on the thermostat housing, its a little two pin switch.
hook one of those wires to the control side (coil) of the fan relay, and the other to ground.
That way when the engine gets hot, the switch will close, energize the control side of the relay, and close the high amp connection to the fan, turning it on. This is how most cars kick the fan on.
Old Oct 13, 2007 | 08:45 AM
redsi89's Avatar
Default Re: (slowcivic2k)
follow your lower radiator hose to where it connects to the engine that is your thermostat housing
Old Oct 13, 2007 | 09:08 AM
bless341's Avatar
alright thanks! Ill give that shot.
dman81
May 28, 2014 03:20 AM
EK9JSPEC
Aug 27, 2012 09:11 PM
axeldc2
Aug 30, 2009 08:28 PM
civic4g63
19
Jun 11, 2007 09:41 AM
BanEL
May 9, 2007 04:46 AM
