Perfromance chip
Old Jun 20, 2002 | 04:46 AM
Ekco's Avatar
Default Perfromance chip
I got a chip fro my car but the only problem is that I can't find anyone in my area, Albany, NY, to put it into the ecu for me? Any suggestions?
Thanks
Old Jun 20, 2002 | 04:47 AM
hybridreams's Avatar
Default Re: Perfromance chip (Ekco)
What ECU? What chip?
Old Jun 20, 2002 | 04:48 AM
Ekco's Avatar
Default Re: Perfromance chip (hybridreams)
Sorry, 94 Del sol Si, reprogrammed chip, 9000 rpm limit, no fuel cutoff, increased fuel/air mixture ratios?
Old Jun 20, 2002 | 04:51 AM
eg6ajk's Avatar
remeber that there is more to chipping a P28 ECU then just a chip, there are few more components, unless you have them it will not work.
Old Jun 20, 2002 | 04:53 AM
Ekco's Avatar
Default Re: Perfromance chip (eg6ajk)
Like what, I got some capiciators and another chip and a rom. Is that what you meant?
Old Jun 20, 2002 | 05:46 AM
eg6ajk's Avatar
74hc373, 10k ohm resistor, jumper, the others are optional
Old Jun 20, 2002 | 05:56 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I must ask what the **** you need those specs for the D16Z6 motor?
Rev that thing to 9000rpm (if you get there) and see what happens.
That motor probably stops making good power at 6900rpm or so. I used to have one and I can tell you that it didn't feel like it had much more power left as the 7200rpm limit was approaching.
Old Jun 20, 2002 | 05:59 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Perfromance chip (B18C5-EH2)
...And you did say Del Sol Si so I assume you mean the SOHC VTEC (D16Z6) powered Si and not the VTEC model.
Old Jun 20, 2002 | 06:28 AM
Ekco's Avatar
Yea it is the D16Z6, I didn't get it to raise the cutoff, I got it because I wanted quicker acceleraton and I thought I would get it throught the mixture increase.
Old Jun 20, 2002 | 06:33 AM
94CivicSi's Avatar
the only shop I know of in Albany is APG. I got my Progress bar from Adam up there. Nice kid he may have a contact that can get you going in the right direction.
Old Jun 20, 2002 | 06:35 AM
Ekco's Avatar
Default Re: Perfromance chip (94CivicSi)
Yea I already talked to him and all he told me was that he could order me a whole new ECU for like 300 bucks. I just need to find a place to get this chip but into my ECU. Thanks though I appreciate the reply
Old Jun 20, 2002 | 06:44 AM
eg6ajk's Avatar
if you send it in to me I can do it really cheap or simply buy already chipped ecu
Old Jun 20, 2002 | 06:45 AM
Ekco's Avatar
how much do already chipped ecu's run for, it is goin into my daily driver so I really can't send it out for an extended period of time. Thanks for the offer though.
Vtec140
Oct 3, 2017 02:15 AM
WeB
Engine Management and Tuning
Jan 19, 2010 11:17 AM
chris61988kb
13
Jan 19, 2007 10:28 AM
evilhatch2.0
Apr 30, 2006 07:57 AM
Terry_shum
Mar 9, 2004 06:15 AM
