Need help with Gsr cluster!!
Old Oct 12, 2007 | 06:24 PM
GserpleaSR's Avatar
Default Need help with Gsr cluster!!
Ok so i got this 99 Gsr that was a theft, had no ecu, motor, cluster ect.. so i found wrecked 01 Gsr. I swaped everything over except the ecu because found out it wouldn't work with the 99 harness so i got a 99 Gsr ecu and the car runs fine! The problem is the the 01 Gsr cluster RPM's dont work, the turn signals arrows in the cluster always stay on, the temp gauge doesn't work, the cruise control light on the cluster always stays on!. Do i need to get a 99 Gsr cluster? can i make the 01 cluster work with the 99 harness? When i got the wrecked 01 gsr the motor ran fine and the cluster had no problem!m Please help!!! I already Search and found nothing!
Old Oct 12, 2007 | 07:30 PM
BlueIntegraBoy's Avatar
Default Re: Need help with Gsr cluster!! (GserpleaSR)
Repin your 99 harness to 00-01 spec.
https://honda-tech.com/zerothread?id=1053318
Old Oct 12, 2007 | 07:50 PM
GserpleaSR's Avatar
Default Re: Need help with Gsr cluster!! (BlueIntegraBoy)
Thanks! i will try it and see what happens!
Old Oct 12, 2007 | 08:00 PM
It should. There's quite a bit of difference in the 13-pin plug.
Old Oct 12, 2007 | 08:08 PM
GserpleaSR's Avatar
will that cause the tach not to work?
Old Oct 12, 2007 | 09:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GserpleaSR &raquo;</TD></TR><TR><TD CLASS="quote">will that cause the tach not to work?</TD></TR></TABLE>
Since the ground is in another pin, yes.
Old Oct 12, 2007 | 11:11 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
i swapped an 00 gsr cluster in my 94 gsr teg and the cluster went crazy wudnt function right found out i need to put the green flim from the 94 onto the 00 cluster the green mesh im talking about is on the back of cluster
Old Oct 13, 2007 | 01:25 AM
Default Re: Need help with Gsr cluster!! (DOHCgarage919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 &raquo;</TD></TR><TR><TD CLASS="quote">i swapped an 00 gsr cluster in my 94 gsr teg and the cluster went crazy wudnt function right found out i need to put the green flim from the 94 onto the 00 cluster the green mesh im talking about is on the back of cluster</TD></TR></TABLE>
He doesn't have the luxury of swapping the film because it got stolen.
Hiroshima_VTi-S
Jul 8, 2007 05:08 AM
bigbadboy
Apr 21, 2007 02:57 AM
ripperbone
Mar 13, 2006 07:18 PM
ej0513
Nov 2, 2003 02:38 PM
topspeed86
May 5, 2002 09:32 AM
