OBD2a OBD2b whats the difference?
Old Oct 12, 2007 | 01:03 PM
St Jimmy's Avatar
* B A N N E D *
Default OBD2a OBD2b whats the difference?
Im going to be swaping a longblock in for a friend, he has a 96 Civic EX but the motor we are swaping in is out of a 99 Civic EX. Is there anything I need to switch over, or is the only difference in the ecu?
Thanks.
Old Oct 13, 2007 | 01:45 PM
LastGenEK's Avatar
Default Re: OBD2a OBD2b whats the difference? (St Jimmy)
There is no difference in the engine harness
Old Jan 3, 2008 | 11:56 AM
MilanoRed_EJ8's Avatar
The 96 is OBD2a
The 99 is OBD2b
Just buy a conversion harness and you can reuse everything.
Old Jan 3, 2008 | 12:39 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: OBD2a OBD2b whats the difference? (MilanoRed_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRed_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">The 96 is OBD2a
The 99 is OBD2b
Just buy a conversion harness and you can reuse everything.</TD></TR></TABLE>
The obd2a ecu and harness worked fine and everything plugged into the obd2b motor. No conversion harness needed.
Old Jan 3, 2008 | 04:14 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
The obd2a ecu and harness worked fine and everything plugged into the obd2b motor. No conversion harness needed.</TD></TR></TABLE>
You would need a conversion harness if you were trying to plug an OBD2b ECU into an OBD2a harness.
Old Jan 3, 2008 | 05:22 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: OBD2a OBD2b whats the difference? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
You would need a conversion harness if you were trying to plug an OBD2b ECU into an OBD2a harness. </TD></TR></TABLE>
Thank you captin obvious
Old Jan 3, 2008 | 05:36 PM
Padawan's Avatar
Darth ModerVader
Relax. I was clarifying for the other posters, who were completely correct in assuming you'd need the conversion harness since you never originally mentioned swapping the entire engine harness.
tommyboy042281
21
May 4, 2009 06:20 PM
Crasian
Sep 15, 2007 04:08 PM
invisible
Nov 19, 2006 09:23 AM
accordmandan
Nov 10, 2005 10:03 PM
charjacq
Nov 21, 2004 08:04 PM
