One set of new Toyo RA-1's for cheap!
A SET OF FOUR 205/50R15 TOYO RA-1'S FOR $500 shipped to lower 48 states or $450 picked up!
Only one set in stock and it will not be parted out. Local pick-up is welcome and we can ship too for an extra charge. Unit is brand new and never rolled on. Most places sell these for an excess of $550 for a set. Here's a little something from Toyo's brochure literature. If you have any questions, please feel free to let me know! Thanks.
The performance-proven RA1™ features high-tech components to provide an uncommon advantage to the cost-conscious competitor who still demands quick lap times. It’s true performance from Toyo!
General Proxes RA-1 setup guidelines:
Operating Temperature: 140°F to 220°F, optimum around 200°F
Hot Inflation Pressures: High 30s to Low 40s (psi)
Camber: -2.5° to -5.0°
Caster: As much positive as possible
Click here for recommendations for proper use, handling and storage of this tire in colder climates.
Features and Benefits
Competitive Handling Soft but durable tread compound
Advanced race-proven casing design
Two steel belts
Spiral wound cap ply (construction may vary by size)
Steel wire reinforced sidewalls (construction may vary by size)
Steering Response Heavy-duty bead construction
Steel belted construction
Wet and Dry Traction Stepped tread design
Tread depth can be shaved to maximize dry traction
Full tread depth of 8/32nds provides aggressive wet traction
Treadlife Steel belted construction
Treadwear Warranty Information (ask your Toyo Tires Dealer for details) Workmanship & Materials
Additional Information UTQG 100 AA A
Modified by CityTireOnline at 11:02 AM 11/28/2007
Two steel belts
