help with auto trans
car is 3rd gen lude
trans- automatic
year- 88
engine- 2.0
trim- 2.0si
ok heres the problem when i use my sport shift/s3-s4 my car works fine but right after i use it and then put it in drive it doesnt grab the gear. all i get is the rpm to go up but then i put in neutral and back in drive and it works fine but i get a check engine light any help would be great and greatly appreciated thanks in advance
luey
trans- automatic
year- 88
engine- 2.0
trim- 2.0si
luey
I have a 90 prelude w s3 s4 shift as well and what I've learned is that you can't do it on the fly and if you check you ECU it should have a LED read the number of blinks and it well give you that code and if that doesn't then you could've done something to the tranny and its not reading right thats all I have good luck
samkim0108
Oct 30, 2010 12:09 AM
vertigocivic
16
Sep 5, 2008 05:11 PM
archer806
Sep 1, 2006 07:44 PM
