Is it normal for Upper Heat Shield to start rattling?
Old Oct 12, 2007 | 10:21 AM
DJLikwid's Avatar
Default Is it normal for Upper Heat Shield to start rattling?
2000 GS-R
DD (used in winters)
From what I understand (but I'm a nooB), there's an upper and lower heat shield under the car. I was getting some rattling about a year or two ago and my guy went under there, said its the heat shield and took it off (didnt get a new one), and the rattling was gone.
Now I'm getting a similar rattling and I'm wondering if it could be the upper part of the heat shield. Is it normal to start rattling? (my guy said its normal for the lower part to start rattling).
If it is the upper shield, do i need to replace it or just take it off?
Thanks.
Old Oct 12, 2007 | 11:06 AM
DJLikwid's Avatar
Old Oct 12, 2007 | 11:14 AM
denieone's Avatar
Default Re: (DJLikwid)
take the upper shield off & just leave it off.......
I had the same problem, three years ago
& I took it off
Modified by denieone at 8:25 PM 10/12/2007
Old Oct 12, 2007 | 02:20 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
Default Re: Is it normal for Upper Heat Shield to start rattling? (DJLikwid)
I took mine off too.
Old Oct 13, 2007 | 02:07 PM
lmike6453's Avatar
mines rattling hard and i want to take it off but heard that the heat will rust center console bolts and will be impossible to take off in future
Old Oct 13, 2007 | 02:26 PM
boogaov's Avatar
he is right. the heat will speed up the rusting process.
Old Oct 15, 2007 | 09:19 AM
DJLikwid's Avatar
maybe a good idea to replace with a new one?
Old Oct 15, 2007 | 10:31 AM
vsmdc4teg's Avatar
^ Or just leave it off
Old Oct 15, 2007 | 10:51 AM
teggsr925's Avatar
Default Re: (vsmdc4teg)
i took all the heatshields for my exhaust off, no more rattling, i love the sound of quiet
Old Oct 15, 2007 | 11:31 AM
lmike6453's Avatar
well it's just tack-welded on so replacing wont do much...need to weld it better
Old Oct 15, 2007 | 02:14 PM
DJLikwid's Avatar
Default Re: (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">well it's just tack-welded on so replacing wont do much...need to weld it better</TD></TR></TABLE>
when i looked at the lower shield after they took it off, it looked like it was b/c the points that hold the bolts on were rusted away, which is why it started rattling. if there was a new one, it seems like it would last a couple years (like when you buy your car new).
has anyone experienced rusted bolts w/o the shield?
Old Oct 15, 2007 | 02:23 PM
SleeperGSR's Avatar
i'm upgrading my exhaust i'm going to try a magnaflow high flow cat. I don't think cutting something off is necessairly a "fix". Also i saw a type R cat on H motors for like 100$, that might be something to look into.
Old Oct 15, 2007 | 04:41 PM
B.J.'s Avatar
Default Re: (SleeperGSR)
The heat is not that big of a deal its a honda it will rust. If its making noise and ripping it off does'nt make the exhast leak go for it. its alot cheaper that way
Old Oct 16, 2007 | 06:10 AM
DJLikwid's Avatar
i'll probably just end up taking it off and not replacing it.
Old Oct 16, 2007 | 06:34 AM
lmike6453's Avatar
i'm waiting for my car right this second as someone is re-clamping mine...all you need is tight clamps from where it is loose...my rattle is in the front of the car
gosu08
Jan 9, 2007 07:59 PM
matt21civ
Apr 12, 2006 11:25 AM
bigmikerich20
Oct 20, 2005 04:29 PM
Rick
Apr 12, 2004 05:04 PM
slimbo
Mar 24, 2002 11:36 AM
