starting problem with Walbro 255 fuel pump
Old Oct 12, 2007 | 08:21 AM
vietxdragon's Avatar
Default starting problem with Walbro 255 fuel pump
ok so i have stock gsr it used to be boosted, this is why its on my car, the fuel pump now. Everything is stock but the fuel pump. I also drilled a little orifice hole in the stock FPR. My car has alwase had a problem starting. I would have to turn the key on the first time and let it completely prime, then when i'd try to start it , it wont start. so now i woudl have to prime it twice then it'll start. is it because i drilled a hole in the FPR a while back? i had to do that because i ddint have a adj. fpr and it'd help with lowering fuel pressure? whats the problem?
Old Oct 12, 2007 | 08:44 AM
thewrai6th's Avatar
Default Re: starting problem with Walbro 255 fuel pump (vietxdragon)
Stock fuel pump FTW!
Drilling your FPR was not a good idea. A valve in the line would have been more useful.
Old Oct 12, 2007 | 08:48 AM
St Jimmy's Avatar
* B A N N E D *
Have someone cover the hole or put something over it and try starting with only priming it once, that will let you know if its your hole or not.
Old Oct 12, 2007 | 09:27 AM
Default Re: starting problem with Walbro 255 fuel pump (thewrai6th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">Stock fuel pump FTW!
Drilling your FPR was not a good idea. A valve in the line would have been more useful.</TD></TR></TABLE>
yeah, i need the fuel pump because im piecing together a turbo kit and my car will be seeing boost once again! you know how boost works! its like a drug!
Old Oct 12, 2007 | 09:32 AM
thewrai6th's Avatar
Then either deal with the Walbro annoyances, or switch back to stock for now. I gurantee that you are running WAAAYYYY rich, if you have not tuned for the added fuel pressure.
It's best to get all the turbo parts together and install them at once. Adding one thing at a time (and trying to drive around) will cause you alot of stress and headaches.
Marco506
Honda Ruckus and Scooters
Mar 31, 2018 03:52 AM
VRD^sam
Aug 15, 2007 12:53 PM
AcidFr33ze
Aug 7, 2005 10:21 AM
Boognish
Jul 24, 2005 06:03 PM
