throttle body
I want a new intake manifold and throttle body is it possible to use any of these off anther engine that would fit a d16 or do I have to get aftermarket ones?
Find out what size throttle body the manufacturer recommends with their intake manifold.
You can use a B series throttle body or an aftermarket one, but anything over 60mm will be overkill on a d16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">A bigger tb wont benefit you unless you are FI or have a wild non-streetable cam. Learned this the hard way by trying a B18 tb on a D16Z6.</TD></TR></TABLE>
Throttle body selection depends primarily on plenum volume and cam profile.
see wat i would do is look for a good job, buy johns LCA and DC bar, then get some bobay tires, then buy a blox trottle body and spacer, hondata manifold gasket aem fuel rail and reg then save all the money u can and buy some RC injectors 350cc(ooohwee) and buy marios vtec controller. youll be flying
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARMYGREEN96 »</TD></TR><TR><TD CLASS="quote">see wat i would do is look for a good job, buy johns LCA and DC bar, then get some bobay tires, then buy a blox trottle body and spacer, hondata manifold gasket aem fuel rail and reg then save all the money u can and buy some RC injectors 350cc(ooohwee) and buy marios vtec controller. youll be flying
Are you for real?
</TD></TR></TABLE>Are you for real?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARMYGREEN96 »</TD></TR><TR><TD CLASS="quote">lol yeah </TD></TR></TABLE>
Um...
Well, I'm sure you know what I'm going to say.
Um...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djessenz »</TD></TR><TR><TD CLASS="quote">Want major speed? I'm talking crazy speeds. Set your V-TAK to 700rpm and you will be flying in no time!</TD></TR></TABLE>
Just make sure you're not low on VTAK fluid, or your engine might become unstable and trigger a thermonuclear reaction...
I'll bet reading gives you a headache, huh? All those words and no brain to put them in order. Such a shame. Don't reproduce.
-Management
</TD></TR></TABLE>I'll bet reading gives you a headache, huh? All those words and no brain to put them in order. Such a shame. Don't reproduce.
-Management
