ARP rod bolts for b20vtec build?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">8mm is the correct size. You must have the hole re-sized.</TD></TR></TABLE>
the 9mm won't fit the ls or crv rod. incase OP is wondering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_student »</TD></TR><TR><TD CLASS="quote">Do you have to have those pressed in? or can it be done at home?</TD></TR></TABLE>
you have to take the rods and rod bolts to a machine shop and have them machine both for fitment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">
shows how much you know
Well considering you are asking for bolt sizes then yeah take it to the machine
The rod bolts fit without machining, the bore in the rod is the one that needs machining after installation...
</TD></TR></TABLE>shows how much you know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">for sure use ARP rod bolts and hopefully you get something like this in the end
Stop it. It's becoming borderline trolling now.
</TD></TR></TABLE>Stop it. It's becoming borderline trolling now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune »</TD></TR><TR><TD CLASS="quote">
The rod bolts fit without machining, the bore in the rod is the one that needs machining after installation...</TD></TR></TABLE>
i believe Eugene @ Prostreet Import used slightly larger rod bolts than the stock ones...that's why the rods had to be machined. are you guys just using the ARP stock OEM replacement bolts??
The rod bolts fit without machining, the bore in the rod is the one that needs machining after installation...</TD></TR></TABLE>i believe Eugene @ Prostreet Import used slightly larger rod bolts than the stock ones...that's why the rods had to be machined. are you guys just using the ARP stock OEM replacement bolts??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">
Stop it. It's becoming borderline trolling now.</TD></TR></TABLE>
lol it's beyond that point..but joe is cool so he gets a pass.
it's kind of like owning a type r and posting in the ITR forum when half the people there know you..
if you own one and post something it almost doesn't matter what it is..
but if someone who owns a civic or gsr posts in there they get all uptight/skeptical.
but hey, that's just my (as well as a couple others i know) opinion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ipodhustle »</TD></TR><TR><TD CLASS="quote">
thank you for the vouch sir...i actually did find another dyno sheet that was printed out after some cam gear adjustments to my motor. it was overlapped with the dyno sheet above but like some people say...it's bordering on trolling
lets see it
</TD></TR></TABLE>lets see it
Damn, dude again. Do you sleep with it at night besides your pillow, seriously?
Honestly, what does that have to do with arp rod bolts? I'm not hatin either, but damn homey.
The 8mm ARP rod bolts are the same used on all B/D series engines except the B18C models. I installed mine at home using a socket and a C-clamp, worked like a charm but was easier with a friend to help hold stuff still while you crank. After that is when you take the reassembled rods (with original caps back on the rods they came off) to have them set back into round again.
gstrudler
Apr 19, 2012 09:39 PM
