Need help on fixing this dent.
So I received this dent when I accidently hit a low curb. I would like to know how to approach this dent without cutting and welding. I was thinking of using a slide hammer, weld up the tiny holes, bondo and lastly primer. What other methods are there that I'd be able to use. I would assume its say to say I will need a way to shrink the metal if the slide hammer pulls it out too much. Thanks in advance
Thanks Guys! Any other options, I am not in the budget for a $150 stud gun. I have a cheap 110v Chicago mig welder if thats of any help. Paintless dent removal? LOL
paintless dent remover is not foing to do the job ill tell u that much pull it out and then try your best to even it out good luck
Stud gun is not going to be much good on that dent anyway. You need a frame rack as already stated so you can weld a tab on and make some pulls. Or at least weld a tab on it and use a Morgan Knocker (big *** sllide hammer). I'd replace a section of rocker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_srt »</TD></TR><TR><TD CLASS="quote">Stud gun is not going to be much good on that dent anyway. You need a frame rack as already stated so you can weld a tab on and make some pulls. Or at least weld a tab on it and use a Morgan Knocker (big *** sllide hammer). I'd replace a section of rocker.</TD></TR></TABLE>id go for the rocker replacement personally myself, more wok, but a better finished product
vtecn8ive
Mar 3, 2005 10:23 AM
vtecguy
Sep 18, 2001 06:12 AM
