What type of Pistons?? ITR or EK9???
aight guys i have an OEM all motor build. i am running ek9 cams on my head. i had a question about the bottom. as i am starting to gather parts for the bottom end, i wanted to know which OEM honda pistons are best to use???
EK9, USDM Type R, or JDM Type R???
i think only the USDM Type R pistons will pass smog correct?
thanks guys i appreciate it!
building a b16a2...head is all done up and now i got the bottom end to work on. i am still debating if imma swap out the crank or not for something else.
is p30 the JDM B16a pistons? will that pump more power than ITR or EK9 pistons?
i pretty much the best OEM honda b series pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungMoneySi »</TD></TR><TR><TD CLASS="quote">so the p30 pump out higher compression than Ek9 pistons?</TD></TR></TABLE>
edit:
no. lower. ctr compression is not as high in a b16 block due to the smaller stroke, unlike a 1.8
Modified by Brick Top at 5:25 PM 10/12/2007
edit:
CTR pistons are too much of high compression. thats why i said JDM p30.. close enough. a little better then ITR compression wise i believe.. unless I'm wrong someone correct me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meots98itr »</TD></TR><TR><TD CLASS="quote">list your mods please. </TD></TR></TABLE>
if all the smog components are good (o2 sensor, catalytic converter, timing ), CTR pistons in a b16a should be able to pass smog. im not sure how much more compression those pistons will bump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia »</TD></TR><TR><TD CLASS="quote">
CTR pistons are too much of high compression. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brick Top »</TD></TR><TR><TD CLASS="quote">
ctr compression is not as high in a b16 block due to the smaller stroke, unlike a 1.8 </TD></TR></TABLE>
GsrSleeper18
Apr 1, 2005 03:55 PM
dsosa51
15
May 28, 2004 10:34 AM
