Temp sensor
Old Oct 11, 2007 | 05:38 PM
4GE4YA's Avatar
Default Temp sensor
I have tired to search with no luck. I have installed an autometer coolant temp gauge in my 90 model hatch with a b16 swap. The gauge power up and zero's out but does move from zero. I know for a fact the thermostat is opening. I was wondering if my ground really need to be close to the sender like the instruction state? I have it grounded under the dash.
Old Oct 12, 2007 | 04:25 AM
B18EG6's Avatar
Default Re: Temp sensor (4GE4YA)
how many wires does the sender have coming off of it?
did you check for true ground at where you grounded it?
Old Oct 12, 2007 | 10:19 PM
4GE4YA's Avatar
Default Re: Temp sensor (B18EG6)
Its got 1 wire on the sender. Its for the signal to the gauge. Then you have a switch 12 volt power and a ground on the back of the gauge.
dejay2014
May 16, 2014 02:36 PM
- Sim -
Sep 22, 2004 09:44 AM
pburke23
Jul 2, 2004 09:55 AM
TurboJesse
Sep 25, 2003 04:15 AM
