Cranks
Old Oct 11, 2007 | 04:47 PM
J_M_B's Avatar
Default Cranks
I have an LS motor and i am getting a new crank for a motor that i am building for boost anyway the site i am getting it from has 89mm, 92mm, and 95mm what is the difference for boost heads.
Old Oct 11, 2007 | 05:41 PM
doood's Avatar
been there done that
Default Re: Cranks (J_M_B)
89mm cranks are straight drop in with stock length rods. 92+mm cranks require custom rods or pistons and a competant engine builder to check clearances. if you're not building a drag engine, stick with the stock stroke.
Old Oct 11, 2007 | 05:51 PM
Luserkid's Avatar
Default Re: Cranks (doood)
89 is the stock LS/B20 stroke and are perfectly fine for turbo aps. Higher strokes are usually for NA apps.
89 pos
Apr 12, 2005 06:05 PM
p1ccoloz
May 1, 2003 02:09 PM
ezark
Dec 25, 2001 11:30 AM
dohc_Cx
Aug 12, 2001 06:57 PM
