Electrical Problem Help If You Can
Old Oct 11, 2007 | 01:48 PM
lengyx's Avatar
Default Electrical Problem Help If You Can
Hey everyone I just bought myself a 1991 crx si and well it runs like a champ, but im having issues with the electrical system. The problem with it is that everytime you got to hit the brakes the seatbelt light comes on and it starts to ping like when you jump in the car also the brake lights are out. Just off the top of anyones head do you have an answer. Im thinking bout checking the brake light switch and well im not really in the mood to trace every single wire.
Old Oct 11, 2007 | 01:51 PM
wiZCo's Avatar
Stouts 'n' Scotch
Trace the wire coming from the brake switch, it sounds like it's grounding out on something. This may or may not be that's keeping your brake lights out. If your dash lights are out as well, it's a fuse.
Old Oct 11, 2007 | 03:59 PM
The_Undertaker's Avatar
75.168.105.221
Remove rear plasric panel and inspect the looms of wires. There may be a short to ground and I bet money that the brake light fuse is out. Looms of wire tend to vibrate and rub against each other exposing the copper wire that is a short. I AM sure this is the problem there was a honda crx tech video back in the day in early 90's. Same symtoms like yours. I will TRY to find it in my catalog.
Old Oct 12, 2007 | 10:04 AM
lengyx's Avatar
Default Re: (The_Undertaker)
Yeah i was thinking that it was a short also, by the way the brake light fuse wouldn't be the same as the fuse for the horn now would it. Unless im just not looking in the right place. I can't seem to find it. Except for it says stophorn on the horn fuse. I had to pull that out since it was also tripping off the horn. But thanks for the tip. If you got anymore helpful tips that might help me dont hesitate to help me out. thanks
Old Oct 12, 2007 | 10:12 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote"> If your dash lights are out as well, it's a fuse. </TD></TR></TABLE>
So, it's not a fuse then?
Have you traced the brake switch wiring or tested it with a DMM yet?
misha
Dec 5, 2010 06:15 PM
boush95ls
Apr 30, 2009 01:42 PM
98integralsB18
Aug 26, 2008 09:21 PM
Integra_Nguyen
Sep 10, 2004 02:31 PM
