what do these codes mean
so i just got done doing my dpfi to mpfi swap
started it up and its ideling really hi like 2800 rpm
and now im getting a code 7 which is tps
and im getting a code 43 (fuel suply system
so im wondering if i should switch back the wires on the tps
and what do i do about the supply system
do i need to change my fuel pump ????
Don't know if you read this already but its about all the help I can give
https://honda-tech.com/zerothread?id=1558301
Was the car running fine before you did the swap?
If so they its something you did, check your wiring, check though the entire process of what you did.
i did and it came back as a fuel supply sustem
does this mean too much fuel or not enough
that is all i want to know
if you dont have any info thenstay off my thread
jeeze is it that hard to understand
and yes jonny red it was running fine
and after it was runnign fine too
it still runs fine now but im gettng this code
im wondering if it has to do with the fact im using a accord resistor box and a chpped ecu ????
civickid99
Aug 17, 2004 12:12 PM
