REAR CAMBER KIT ON 02 RSX W/ EIBACH PRO KIT?
Old Oct 11, 2007 | 11:05 AM
1sIcKrSx's Avatar
Default REAR CAMBER KIT ON 02 RSX W/ EIBACH PRO KIT?
I HAVE AN 02 RSX-S WITH THE EIBACH PRO KIT SPRINGS AND 18" VOLK TE37'S
AND WANT TO CAMBER IN THE REAR BUT IS THAT ANGLE REDUCTION GOING TO
LEAVE ME WITH NO FENDER WELL CLEARANCE. DO I HAVE TO ROLL IN THE REAR
FENDERS TO CLEAR THE TIRES?
Old Oct 11, 2007 | 11:51 AM
1sIcKrSx's Avatar
Default Re: REAR CAMBER KIT ON 02 RSX W/ EIBACH PRO KIT? (1sIcKrSx)
I'VE SEEN LOTS OF REX'S WITH STRAIGHT WHEELS IN THE REAR BUT FROM THE
PIX I CANT TELL IF THE FENDERS ARE NORMAL OR ROLLED IN FROM THE SHADOWS.
Old Oct 11, 2007 | 03:24 PM
concept11253's Avatar
STEP 1. LOOK AT KEYBOARD
STEP 2. PRESS CAPS LOCK
You need either the ingalls or SPC rear camber kits. The front tires should be fine but you definitely want to get that fixed asap. Having bad camber creates uneven tire wear and not to mention that it looks ghetto.
Old Oct 11, 2007 | 03:35 PM
1sIcKrSx's Avatar
Default Re: (concept11253)
yeah, the camber is a tire killer, but am i going to run into any problems with tire clearance during suspension travel hitting the inside of the fender wells? that is my main worry.
Old Oct 11, 2007 | 07:44 PM
WhiteOnRice's Avatar
When I got my kit installed and the car aligned I rubbed on the quarters. I rolled them and was on my way (using fender rolling tool, not a bat or any other bs).
Old Oct 12, 2007 | 03:19 AM
nahonda04's Avatar
Surje.motorsports
Default Re: (WhiteOnRice)
what size wheels/tries are you running?
Old Oct 12, 2007 | 06:39 AM
1sIcKrSx's Avatar
Default Re: (nahonda04)
18X7.5 40 SERIES,
Old Oct 12, 2007 | 06:41 AM
1sIcKrSx's Avatar
THAT WAS THE ANSWER TO MY QUESTION, SO YES WHEN REAR CAMBER KIT INSTALLED YOU NEED TO ROLL THE FENDERS, IT'S REQUIRED BASICALLY. BODY SHOP FOR A FENDER ROLLER, OR CAN YOU GET OR ORDER ONE FOR CHEAP? THANX FOR THE INFO.
tortis
Suspension & Brakes
Jul 10, 2010 04:42 AM
crazyguy
Jan 3, 2008 12:33 PM
memo69
May 18, 2007 07:21 PM
xhatchracerx
Jan 27, 2003 03:17 PM
