Strange noise
my mate has a EDM Integra type R, he has had it for over a year now, he says he keeps on hearing a 'knock' of some sort, he can hear it at idle and sometimes through the exhaust and sometimes sounds a bit intermitant, i cant really explain what it sounds like but i just thought id ask. To me it sounds like its coming from the back of the engine.
Car: Approx 80k, DC Stainless Manifold,Full stainless custom exhaust, aem CAI apart from that, its comp stock. keeps it in a1 condition.
Thanks in advance
Thanks in advance
damn dude can you provide me with more of what the problem is. like when it idles or how about driving it normally? the knocking is from the back of the engine? tried finding a lift and jacking the car up?
it sort of goes ........tock tock tock tock.....................tock tock tock tock................tock tock tock tock, like its not consistantly making the noise its intermitant, drives normally, still pulls like a trooper, not sure whether he has got under the car or not, he seems to think it could be the bottom end but i would of thought if it was then things would get worse very quickly, i know most hondas are noisy but this is different from the usual tappy tapp.
i was just after ideas of what could be making the noise, LMAs? Injectors? i aint a mechanic so i aint really got a clue, just fishing for ideas.
if it doesn't make a noise constantly, or in rythym with the revs of the engine....
does it vary when you change the throttle position and alter the load on the engine?
does it happen when you lift off, keep the throttle on, when you're sat still, at idle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adamd »</TD></TR><TR><TD CLASS="quote">where abouts is Bumville then?</TD></TR></TABLE>
near Cambridge
regarding the noise, i really can't put my finger on it. i did have an idea but it doesn't sound like it. i think you may be waiting for someone else to chime in thats had something like this before
near Cambridge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRViet »</TD></TR><TR><TD CLASS="quote">haha yea dude, sounds like something that needs to be physically checked out. sorry man </TD></TR></TABLE>
Usually always is...
Get under the car and look at where the cat and pipe meet - the connection may be loose. Sounds like there may be something swinging around because it isn't properly attached (hanger, flange connection, etc). Maybe even a loose heat shield.
