blown exhaust manifold gasket cause the turbo to spool slow?
Old Oct 11, 2007 | 07:21 AM
91integraLSVTEC's Avatar
Default blown exhaust manifold gasket cause the turbo to spool slow?
Ive lost 11psi of boost in 3 days. I thought boost was leaking from the BOV so plugged it with a silicon coupling and still not building boost past 10. my exhaust manifold gasket is blown i'll be replacing it today but would that cause my turbo to spool so slow? i'm suppose to get 16psi instead ive been getting around 4-5. turbo doesnt sound like it spooling as hard as it did 3 days ago. the turbine has no shaft play and doesnt spin at idle, however i can move it freely when the car is off. please tell me its something simple like an exhaust manifold gasket. thanks in advance.
Old Oct 11, 2007 | 08:53 AM
boosted k20's Avatar
Default Re: blown exhaust manifold gasket cause the turbo to spool slow? (91integraLSVTEC)
a bad exhaust manifold will cause slow spool and less boost. How bad is the exhuast leak?
Old Oct 11, 2007 | 08:57 AM
dpetro1's Avatar
if exhaust cant get to the turbine then it cant spin. fix your leak
Old Oct 11, 2007 | 10:13 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
on average, the boost in your exhaust manifold is usually double what it is in your intake manifold. so in order to run 16psi, that's about 32psi that your exhaust side needs to hold.
think about it for a sec. you're taking 16psi of air and fuel, then blowing it up. by the time that charge leaves the exhaust port, that pressure has gone up quite a bit due to the combustion. it's not like the pressure would go down, unless maybe if you had some horrible rings and leaky valves. i dunno. don't quote me on that...
but basically, yea, an exhaust leak can defintely be the reason why you've lost boost. fix it.
Old Oct 11, 2007 | 01:24 PM
LShatchie's Avatar
Default Re: (full Circling)
when my exhaust manifold gasket blew, my spool time was wayyyy slow and would not build full boost
Old Oct 12, 2007 | 06:08 AM
Default Re: (LShatchie)
oh yes yall was right.. I replaced the exhaust manifold gasket last night and that **** mad a big expletive'n difference! Turbo sounds like a jet engine again, sounds way better than before gasket went! I'm still getting about 5-6 psi of boost, have a major leak somewhere but its spooling hard now.. well now i know my turbo still have a few more years left in it! amazing how much trouble a little gasket can cause..
Old Oct 12, 2007 | 06:43 AM
get that leak fixed. you don't want your turbo to overspin. fixing a big leak like that puts the proper load on it, which prevents it from overspinning.
Old Oct 12, 2007 | 06:49 AM
awdgsx96's Avatar
Default Re: (91integraLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">oh yes yall was right.. I replaced the exhaust manifold gasket last night and that **** mad a big expletive'n difference! Turbo sounds like a jet engine again, sounds way better than before gasket went! I'm still getting about 5-6 psi of boost, have a major leak somewhere but its spooling hard now.. well now i know my turbo still have a few more years left in it! amazing how much trouble a little gasket can cause..</TD></TR></TABLE>
Def check else where for leaks. Do the obvious couplers, BOV, and WG first. For the turbo to pump out air only to leak may eventually overspin it. If you can't find a big leak get out there with some soapy water and get sprayin'
AmericanPie
Jan 1, 2011 01:56 PM
lilintegra25
Jan 18, 2007 01:46 PM
Integra_Boi
Dec 16, 2002 07:59 PM
smoothludey2
Mar 9, 2002 11:47 AM
