Suspension & Brakes Theory, alignment, spring rates....
arp extended lugs
Old Oct 10, 2007 | 11:39 PM
ekeddie's Avatar
Default arp extended lugs
is it possible to press out the spindle with out ruining the wheel bearing, im tryin to install arp extended studs but dont have the money for new wheel bearings
Old Oct 11, 2007 | 03:58 AM
Guam_CiviC619's Avatar
Default Re: arp extended lugs (ekeddie)
it is possible
Old Oct 11, 2007 | 08:30 AM
ekeddie's Avatar
with using a press b/c the hub assembly is off the car so its my only way?
Old Oct 11, 2007 | 10:40 AM
purplecivicturbo's Avatar
Default Re: (ekeddie)
I have just done this myself a few months back.
You dont even need to press the bearing out. I used a axle puller/slide hammer i bought for something else.
All you do is remove the brake parts and undo the 32mm nut on the end of the driveshaft. Attach the axle puller attachment to the hub, screw on the slide hammer and slowly pull back. This pulls the bearing apart, leaving the outer casing and race in the upright and leaving you with the inner casing on the end of the hub.
Simply use a bench vise to press out the studs and press the new ones in.
Old Oct 11, 2007 | 12:03 PM
ekeddie's Avatar
thanks gona give it a try
Old Oct 12, 2007 | 09:14 PM
TheSauceSpot's Avatar
do u really hafta spot weld them in?
Old Oct 13, 2007 | 05:32 AM
ekeddie's Avatar
nope arp studs stay once they are put correctly in place
Old Oct 13, 2007 | 06:26 AM
arite... i had them on my lude and never welded them... what about the skunk2 extended studs... those need welding?
my arp studs lost most of the color... wish i they would stay gold!
Old Oct 13, 2007 | 01:18 PM
ekeddie's Avatar
from what i hear skunk2 and obx studs were crap, but i may be wrong. also yea the color did fade for me to b/c it was just a coating
Old Oct 13, 2007 | 04:34 PM
i wish i could clear coat them and make the gold stay.. it would look sick with some gold rims..
when i put them on my lude i had to remove/replace the wheel bearing, and so did my friend with an EK... so id double check on the install..
Old Oct 14, 2007 | 12:28 PM
ekeddie's Avatar
alrite
do0d
Southern California
Aug 22, 2010 09:47 AM
dadecounty_hxc
Jun 13, 2010 05:28 PM
SomeGoodBud2
Suspension & Brakes
Mar 18, 2007 02:48 PM
sinesterxone
Apr 25, 2006 12:33 AM
dumppp gook
Mar 15, 2004 12:12 PM
