Hows my spark plugs look? Rich or lean or Good
Old Oct 10, 2007 | 05:54 PM
Jonknee's Avatar
Default Hows my spark plugs look? Rich or lean or Good, [srry 56k :( ]
Engine : obd1 d15b vtec, mild build with raised compression.
Spark plug type: d16z6 NGK R - Zfr5j-11 ( CURRENTLY USING)
Recommended spark plug type ( says on timing belt cover) : d15bvtec NGK - Zfr6j-11 .
What is the difference between them?
I searched and there was alot of misinformation, some people said that white meant rich, some said lean, some said timing too advanced or pinging.
What's really going on.
Pictures:
Old Oct 10, 2007 | 05:58 PM
Jonknee's Avatar
Default Re: Hows my spark plugs look? Rich or lean or Good, [srry 56k :( ] (Jonknee)
Ecu throws code 43 once a full moon fyi.
Old Oct 10, 2007 | 06:02 PM
wiZCo's Avatar
Stouts 'n' Scotch
The carbon on the tip usually indicates a rich condition. Doesn't look too bad though.
Old Oct 10, 2007 | 06:10 PM
The_Undertaker's Avatar
75.168.105.221
Code 43 is fuel supply system. Check the fuel pressure, fuel pressure regulator, check the 02 sensor and also check vacuum leaks.
Old Oct 10, 2007 | 06:19 PM
Crx Jimmy's Avatar
Default Re: (The_Undertaker)
to tell the condition you have to do a plug chop. you cant tell how the car is running by looking at the plugs unless the car ignition is cut at the moment you want to check to see if you have a lean or rich condition. the plugs will tell you the last condition they saw, which is probably idle which will run lean since there is no load on the motor.
Old Oct 10, 2007 | 06:58 PM
Jonknee's Avatar
Default Re: (Crx Jimmy)
I wil check my o2 sensor, maybe i am running rich, which might explain the fuel smell i get on idle or when i smash on it. When i do "smash" on the throttle i get a slight smoke on 6k+ , dad was behind me when merging into freeway and said my car smelt like slight cas and dark gray smoke.
im getting 32 mpg though.
thanks for everyones input i appreciate the help
Old Oct 10, 2007 | 06:59 PM
Jonknee's Avatar
Default Re: (Jonknee)
Oh and ill repeat my second question, What are the spark plug differences for the types i metioned above
- whats a plug chop
Modified by Jonknee at 8:42 PM 10/10/2007
zombo
May 3, 2011 06:27 PM
Mr.Death
Sep 28, 2007 08:35 AM
d16dcoe45
Nov 15, 2006 04:49 AM
mickey513
Feb 23, 2004 05:41 PM
Floyd
Jun 18, 2002 01:35 AM
